Home > In Car Electronics > TD5 interiors lights fuse keeps blowing |
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 |
I’m starting to think that the heat over the last few days has caused this.
I’ve taken the roof console down and have insulated all the wiring and the back plates of the interior lights in case they were grounding out on something 🤷♂️ If anyone has any ideas? Click image to enlarge Click image to enlarge |
18th Jun 2022 9:01pm |
Am also thinking two old school bulbs and a USB charger is drawing too much current? But surely not 10a???
18th Jun 2022 9:07pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
Work through the problem step by step.
Does the fuse blow the moment you reconnect the console? If so the usb module may be faulty or you have a short in the console. Check out the console with a multimeter . Does the fuse blow only when the lights come on? Does the fuse only blow when you plug something into the USB port? This may identify the bit of the console with a fault. Try to find the power draw from the console from manufacturers web site. This will let you check the suitability of the fused circuit. Electrical problems are frustrating, you just have to work through and test. |
19th Jun 2022 7:30am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
Check all the wiring in the A pillar very carefully. It is easy to pinch a wire when reattaching the trim piece and cause a short, hence the fuse blowing...ask me how I know!
21st Jun 2022 7:18am |
