![]() | Home > Puma (Tdci) > Missfire/stutter on startup |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Yes the switch is separate from the key barrel/column lock.
Try the relay bridge wire though ![]() ![]() ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2135 ![]() ![]() |
Have a look at the bottom of page 10 of this topic https://www.defender2.net/forum/topic47486-135.html a new technique from bradders130 to get the switch element off the ignition without drilling |
Moffett Member Since: 08 May 2018 Location: Sligo Posts: 69 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/275068205359?mk...media=COPY
Okay, I see now, the contacts are sold separately. I will check out that thread now. |
Before you look to replace the ignition switch check all the wiring and individual connectors to it.
https://www.defender2.net/forum/post933318.html#933318 |
