Home > Puma (Tdci) > Missfire/stutter on startup
Page 2 of 2 <12
Martin
Site Admin
Yes the switch is separate from the key barrel/column lock.
Try the relay bridge wire though Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #955582 15th Jun 2022 12:26pm
Ianh
Moffett wrote:
I see changing can be a bit of a battle. I do have ti remove the key sometimes before I can turn it again from position zero. Changing the switch might be the next job. How do you retain your original key, does the lock section separate easily from the switch?
Have a look at the bottom of page 10 of this topic https://www.defender2.net/forum/topic47486-135.html a new technique from bradders130 to get the switch element off the ignition without drilling
Post #955584 15th Jun 2022 12:52pm
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
https://www.ebay.co.uk/itm/275068205359?mk...media=COPY
Okay, I see now, the contacts are sold separately. I will check out that thread now.
Post #955588 15th Jun 2022 1:19pm
Ianh
Before you look to replace the ignition switch check all the wiring and individual connectors to it.
https://www.defender2.net/forum/post933318.html#933318
Post #955616 15th Jun 2022 5:50pm
Page 2 of 2 <12
