Home > In Car Electronics > There unused connectors behind light? (see pic) |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
From left to right:
- Alarm battery backed sounder - Auxiliary horn/sounder - Rear washer pump (assuming you dont have rear wash/wipe) Steve 02' 110 TD5 Double Cab Rebuild Thread |
7th Jun 2022 5:27pm |
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 |
Thanks for this. Any idea if i can use the rear washer pump wires to control a relay if i use a latching switch instead of a momentary switch? I could then use the latching switch and the wires to toggle a relay controlling lights on the bumper.
14th Jun 2022 12:49pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2310 |
I have done exactly this to switch my winch relay
Click image to enlarge > 110 XS Double Cab |
14th Jun 2022 1:16pm |
Perfect! how did you manage to change the logo on the switch? I've pulled a load of switches out a TD5 disco but obviously the logos are wrong, your logo looks professional!
14th Jun 2022 1:17pm |
And also did you change the switch or is it possible to change a non-latching to a latching switch? |
14th Jun 2022 1:21pm |
Take a look at this thread - should have all the answers to your questions
https://www.defender2.net/forum/topic63641.html > 110 XS Double Cab |
14th Jun 2022 1:54pm |
