Home > In Car Electronics > There unused connectors behind light? (see pic)
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Anyone have any idea what these three unused connectors are for behind my headlight? Thanks in advance
Post #954817 7th Jun 2022 3:30pm
rallysteve
From left to right:
- Alarm battery backed sounder
- Auxiliary horn/sounder
- Rear washer pump (assuming you dont have rear wash/wipe)
Post #954826 7th Jun 2022 5:27pm
phillips321
Thanks for this. Any idea if i can use the rear washer pump wires to control a relay if i use a latching switch instead of a momentary switch? I could then use the latching switch and the wires to toggle a relay controlling lights on the bumper.
Post #955466 14th Jun 2022 12:49pm
hank
I have done exactly this to switch my winch relay
 > 110 XS Double Cab
Post #955468 14th Jun 2022 1:16pm
phillips321
Perfect! how did you manage to change the logo on the switch? I've pulled a load of switches out a TD5 disco but obviously the logos are wrong, your logo looks professional!
Post #955469 14th Jun 2022 1:17pm
phillips321
And also did you change the switch or is it possible to change a non-latching to a latching switch?
Post #955470 14th Jun 2022 1:21pm
hank
Take a look at this thread - should have all the answers to your questions
https://www.defender2.net/forum/topic63641.html > 110 XS Double Cab
Post #955473 14th Jun 2022 1:54pm
