![]() | Home > Technical > Front LT230 OutPut Housing |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
Assuming that you have the high/low selector housing removed, the most likely causes are that either the front output shaft splines are not engaging in the diff side gear (rattle both front and rear flanges to sort this) or the difflock dog clutch is baulking, which is quite likely if either the difflock is engaged or the difflock mechanism hasn't yet been refitted. If it is the difflock hanging up it should be apparent via the side cover, which I presume you also have removed.
Generally when I am stripping or reassembling an LT230 I pop the difflock selector shaft blanking plug from the front of the housing whilst the difflock shaft is out and refit the front housing without the difflock selector fork, shaft, etc., and refit them once the housing in in situ. I find it easier that way. |
Classic110 Member Since: 14 Mar 2021 Location: East Yorkshire & Hertfordshire Posts: 25 ![]() ![]() |
Blackwolf. Thank you for your reply. Yes the High/Low housing has been removed, but I do not know what position it was in when I removed it (hmm). As a last try I removed the output shaft and bearing from the front housing together with the selector fork/shaft and the diff lock dog clutch. it did fit but not without a little bit of a fight. I think it was somehow bulking on the High/Low shaft that protrudes from the main box area! So maybe the shaft is too far forward? I will try taking the diff lock cap out way also.This is my first experience of the LT230 so I am a little green but did and have since read and looked at a lot of information on line prior to doing the job. Really appreciate your help.
As long as the high/low selector fork hasn't been loosened on the selector shaft it shouldn't be possible for it to be so far forward that it impedes the front housing unless some crud or sealant has made its way into the hole the selector shaft fits in in the front housing. It doesn't matter what position it is in, but it is easier to rattle the gears to get the thing assembled if it is not in neutral at this stage.
Usually it is the output shaft splines or the difflock dog clutch teeth baulking. Look on the bright side - when you figure it out this time it will be easier next time! |
The H/L selector/shaft has not been touched as such. So later today I will have another go following your guidance and suggestions. As the housing is off the main box can you get the housing side plate back on once you have put in the Diff Lock parts, it looks a little tight for space. Hands on experience is always the best way, so as you say " it will be easier next time".
Yes, the "T"-shaped cover over the difflock selector can be fitted after the rest of the box is assembled, however I am assuming that the transfer box is off the vehicle, it might be different if the t-box is still fitted to the main gearbox (I've never tried it in situ).
Just an update. Spent more time today looking and trying, but have given up. So out with the TB in the near future
So just to finish off this thread. Got TB back in on Sunday all OK, no leaks and vibration has gone.
