Home > Off Topic > Towing and the LAW
leeds
Towing and the LAW
Personally I think the law regarding towing, trailers etc is as clear as mud. It is so clear that I have known policemen and DVLA/BHS get it wrong. NO I do not pretend to be a legal expert on towing and the law.
So a few questions for people to try and answer without googling the answers.
1) Can a post 97 driver tow a trailer greater then 750 kg without passing a separate trailer test?
2) Can a pre 97 driver supervise a post 97 driver towing a trailer in excess of 750kg 9say 2,000kg)?
3) Is it legal to tow a small car behind a motorhome on an A frame?
4) Is it legal to tow a car on a motorway on a towrope/strap?
5) What is the legal maximum length of a tow rope on UK roads?
6) 750kg+ trailer in UK, legal or illegal without brakes?
7) What is maximum width of a trailer behind car/4x4?
Cool What is maximum length of a trailer behind car/4x4/light commercial?
9) Is it legal to fit a tow bar to all cars in the UK?
10) What is the maximum speed limit of a car/4x4 towing in the UK?
Brendan
PS Why does number eight followed by a round bracket come up as a smiley Cool ?
Post #91047 24th Sep 2011 9:45am
JSG
Re: Towing and the LAW
No
No
Yes
No
Don't know
Illegal
Just under 8' ??
Don't know
No - they have to have type approval for a tow bar
60mph?
That one I know - because 8 followed by a ) is the code for that smiley. John
2011 Tdci 110 CSW XS
Post #91053 24th Sep 2011 10:01am
leeds
I always though smileys had a : before and after the smiley code
Makes a mess of people wanting to numerate a number of points.
Brendan
Post #91056 24th Sep 2011 10:07am
RobKeay
A pre 97 can supervise a post 97 as long as you can take over the driving and you have L plates on
Post #91057 24th Sep 2011 10:14am
leeds
A couple more questions for you all
11) Are HGV's always banned from using lane 3 on motorways in the UK under normal driving conditions?
12) Are cars towing trailers always banned from the outside lane on UK motorways?
Brendan
Post #91058 24th Sep 2011 10:20am
11) No Whistle not all motorways have three lanes
12) Rolling with laughter No unless its a transit with a tarmac roller behind it
Massive holes if you know were they are
Post #91061 24th Sep 2011 10:44am
Romadog
As of April 2010 a pre97 driver is not able to supervise a post 97 driver with trailer. The reason being that they have not taken the 'trailer test' and therefore are unable to give advice to a new trailer driver. Now if pre97 took the latest test and passed then that would be different. If they failed they would still keep their 'grandfather rights' to tow trailers.
Post #91062 24th Sep 2011 10:46am
noworries4x4
That doesn't count as the Transit is going so fast the roller trailer or compressor only touches the road every 50 mtrs bounce bounce bounce If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #91067 24th Sep 2011 11:16am
22900013A
Yes, with restrictions.
No
Sadly, yes
I don't think so
I know you have to put a flag on it its over a certain length...
Illegal if over 750Kg Gross
2.5 M
7 M I think
No
60mph
Brendan
 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #91087 24th Sep 2011 3:39pm
Martin
Site Admin
As an aside, a neater way to number lists is as follows:
[list=1][*]Item
[*]Item
[*]Item[/list]
Which looks like this:
  1. Item
  2. Item
  3. Item
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #91090 24th Sep 2011 3:56pm
Here's my stab at this:
No.
Only if the pre 97 driver has actually pasted the post 97 test. Otherwise, no.
Technically, a-frames are treated no differently to any other trailer, so virtually every car towed by a-frame would have to be modified to link to the brakes. There is doubt about whether cars can be modified to fully meet appropriate regulations but A-frame suppliers will carry out modifications for you and many motorcaravanners are using such towing arrangements every day.
There is an argument that says an a-frame towed car is a trailer but since it can never have auto-reverse overrun brakes fitted it must then be illegal in all cases. A counter argument runs that says, such a car is outside the trailer legislation so auto-reverse and/or overrun braking is not required though under what regulation this then falls is open to question. Different regulations apply, or are applied differently, to recovery vehicles.
No.
From the Police National Legal Database:
"When the vehicles are attached solely by a rope or chain, the maximum distance allowed between the vehicles is 4.5 metres.
If the distance between the two vehicles exceeds 1.5 metres then the rope or chain must be made clearly visible within a reasonable distance from either side to other road users. This is usually done by tying a coloured flapping cloth in the middle of the rope or chain."
Illegal.
The maximum width of a trailer must not exceed 2.3 metres (7’6”) or 2.5 metres (8’2.5”) when towed by a heavy goods vehicle. The trailer must not extend more than 305mm (12”) outwards each side of the towing vehicle, irrespective of allowable width.
8 ) What is maximum length of a trailer behind car/4x4/light commercial?
The maximum permitted trailer body length without the tow bar is 7 metres but the overall train length must not exceed 18.35 metres.
No. Only those that are type approved for it.
60mph Darren
Post #91121 24th Sep 2011 6:18pm
22900013A
A post 97 driver CAN exceed 750KG liimit so long as the train weight does not exceed 3500KG and the trailer weight is not greater than the payload of the towing vehicle. Ironically therefore, a post 97 driver can tow a greater weight behind a 90 than a 110...
Thats what I was taught when I did my B&E earlier this year. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #91124 24th Sep 2011 6:38pm
TJ101
Recon LandRoverAnorak has it about right
A big can of worms
Try another question ?
Can someone who passed their test after Jan 97, and also has passes their trailer test (so has a B & E)
Tow a trailer with a Defender on it
Question California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #91127 24th Sep 2011 6:56pm
22900013A
A big can of worms
Question
Yes I do it all the time. Can they do it with a Nissan Micra? No. But seriously, so long as the trailer does not exceed 3500KG when laden (a 110 is just over two tons, so that on a 850KG trailer would be fine for example) and it is towed by a vehicle capable of towing 3500KG such a Defender or Daihatsu Fourtrak, then yes you are fine. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #91130 24th Sep 2011 7:01pm
leeds
[quote="leeds"]Personally I think the law regarding towing, trailers etc is as clear as mud. It is so clear that I have known policemen and DVLA/BHS get it wrong. NO I do not pretend to be a legal expert on towing and the law.
OK I will try and answer the questions. I am not saying these are definitive answers but are my understanding of the situation
YES up to the 3500kg limit
Category B vehicles with larger trailers i.e. > 750kg, provided that the combined MAM does not exceed 3.5 tonnes and the gross MAM of the trailer does not exceed the unladen weight of the towing vehicle. To be able to tow combinations outside this ruling requires the passing of an additional test.
That is a YES and NO answer
No if they did not take the E test prior to June 2010.
IF they have past the E test after June 2010 they have to wait 3 years
Difficult one. Chances are that the car weighs more then 750 kg so it will more then likely have to come under trailer regs so will need either overrun brakes or connected brakes. Also it is unclear if the A frame needs to be type approved. Another can of worms. Then there is the question of the drivers licence
YES and NO. Yes to a place of safety so it could be towed onto the hard shoulder. Stretching place of safety would be the FIRST exit slip road. NO to an 80mph tow in outside lane for 50 miles
4.5m with a warning flag in the middle.
Again a YES and NO answer. ILLEGAL if bought in UK. Possibly legal if an imported trailer especially if running on foreign plates
2.55m
7m length of trailer excluding towbar and coupling
NO Car must be type approved for towing equipment.
Towing limit as given my manufacturer must not be exceeded!
60mph
They are allowed to use ALL lanes when there are specific signs saying so. i.e. End of old M1 now M621 by Leeds
NO two lane motorways or when inner lanes are blocked by accidents/roadworks
I am willing to be corrected on any of my answers
Brendan
Post #91136 24th Sep 2011 7:39pm
