Home > Maintenance & Modifications > soft clutch and clutch fluid leakage
Match0020
the clutch is soft on my defender and I found no fluid in clutch master cylinder
full filled thr fluid, it back to empty again after few days.
the car still can move, after filled fluid, the clutch biting point is still very slow. do I need to bleed the clutch ?
also, I found many oil in the transmission, how can I fix it permanently?
Post #952574 15th May 2022 8:44am
Dinnu
If air got inside the hydraulic system, then you will need to bleed it.
By the look of it, it looks like the slave cylinder has failed, which on the puma is an integral part of the release bearing assembly. In turn that means it is either a transmission or engine out. I think on the puma, a gearbox out procedure is more easy than engine out.
Have you checked that there is no hydraulic oil in the footwell, inside the cab? Lift out the carpets to check. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #952575 15th May 2022 9:02am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Hi Match0020
The oily stain on the second picture at the front underside of the gearbox is more than likely clutch fluid especially if you've also got a soft clutch and no fluid in the reservoir. As Dinnu has said that will be a failed slave cylinder. If changing the slave cylinder then its transfer case out and gearbox off the back of the engine. With gearbox off also consider changing the clutch (depending on condition) and have a look at the condition of the gearbox / transfer case adaptor shaft too. Lots of threads / info around on this forum.
Andy
Post #952594 15th May 2022 12:24pm
Match0020
Hi Dinnu,
Thanks for your comment.
I haven't check the footwell yet, is it the footwell under the driver seat or the back seat?
Post #952596 15th May 2022 1:52pm
Match0020
piechipsandpeas wrote:
Hi Match0020
Andy
Hi piechipsandpeas,
is it mean i have to change the slave cylinder?
can i just changing the slave cylinder without touching the transfer case and gearbox?
Post #952598 15th May 2022 1:56pm
piechipsandpeas
Unfortunately the slave cylinder is located within the bell housing of the gearbox and slides over the gearbox input shaft
Post #952600 15th May 2022 2:15pm
No, the slave cylinder is coaxial with the primary pinion shaft and is located within the gearbox bell-housing. The gearbox and transfer box must be removed from the vehicle to allow access to the clutch slave cylinder.
There is one benefit to this, however, and that is that it affords the perfect opportunity to check the condition of the output adaptor shaft coupling which is a notorious failure point and spectacular design weakness of the Ford-engined Defender.
Post #952601 15th May 2022 2:16pm
Match0020
thanks guys.
Then I may need to find the professional to do that Sad
just wondering how can I do the bleeding if the slave cylinder is inside bell-housing ?
Post #952607 15th May 2022 3:01pm
Dinnu
By footwell I mean right underneath the clutch pedal. Ensure that it is dry under the carpets and as if the master cylinder is leaking, the hydraulic fluid will end up under the carpets. The hydraulic fluid, which is a dot 4 fluid is corrosive.
The bleed nipple is led outside of the bell housing. It is located on the left side of the bellhousing.
This thread might help: https://www.defender2.net/forum/post376716.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #952615 15th May 2022 4:35pm
It is likely the slave failed, you will need a new clutch and slave as a minimum as transfer box and gearbox has to come out to change the slave. By this stage you may as well fit a new pressure plate and friction plate and as per Blackwood’s suggestion at least check and grease it.
Like me you will need someone else to have a look at it.
Slave cylinders and common to go on Pumas, some have really good luck others don’t.
I’ve found the slave to be more problematic than wearing clutches out. I guess age related.. $W33T $0U7H3RN $UG4R
Post #952627 15th May 2022 5:53pm
Aha, the enigmatic "Blackwood" makes another appearance! Rolling with laughter
Post #952629 15th May 2022 6:40pm
Rolling with laughter I was gonna put that on mine deliberately the other day, but it just so happens it’s gone and posted in accidentally.
Any chance you could change username to it? Snigger Thud Laughing $W33T $0U7H3RN $UG4R
Post #952637 15th May 2022 8:18pm
Not a hope! Laughing Train your predictive text engine. Rolling with laughter
Post #952638 15th May 2022 8:23pm
