Home > Td5 > new tank
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
new tank
Apparently my 2003 TD5 90 has sprang a small leak from the gas tank... Do you have any suggestion on what are my options? Do you know how much is a new tank?
Many thanks
Alex http://instagram.com/h4vou/
Post #952264 11th May 2022 3:57pm
PocketFred
Switzerland 2001 Defender 110 Td5 HT Caledonian Blue
Have you located the leak ? are you sure it's not one of the pump seal or connectors or one of the breather pipes that is at the end of its life ?
The TD5 has a tank made of (durable) plastic and is not known (AFAIK) to spontaneous leaking. 110 HT TD5 w/ PopTop for travelling
110 CSW 300tdi for hunting
Post #952269 11th May 2022 4:16pm
mustafasoleiman
I'll have to check as it is all dirty down there... It's a small leak but it does leave a stain on the floor of diesel.
Thank you
Post #952281 11th May 2022 5:26pm
It would be unusual for it to be the tank itself, it is far more common that a hose connected to the tank ot a fitting in the tank is the source of the leak.
Whilst it is not unheard of for a plastic tank to leak it is unusual.
Post #952283 11th May 2022 5:40pm
jst
its most probably the fuel breather pipe thats perished. did one on Tuesday - 3hrs. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #952307 11th May 2022 7:30pm
mustafasoleiman
Good to know many thanks!
Post #952349 12th May 2022 9:57am
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
My 110 TD5 has a slow fuel drip.
This has been diagnosed by different garages as either the fuel tank breather or the fuel filter head becoming porous.
The fuel filter housing was replaced a couple of years ago with a Gore unit and I therefore think that this is not where the fuel leak is coming from.
Obviously to look at and possibly replace the breather pipe is going to need the tank removed along with the prop etc, etc!
Does anyone have any idea of roughly how many hours the work would take?
Post #955530 15th Jun 2022 12:48am
Linds Hanson
If its a 110 its a doddle compared to a 90 most time will be spent removing towbar stays and anti roll bar mounts if they havent been off in a while. If you only need to change the breather hose it can be accessed by just dropping the tank at the left side enough to get your hand in. Probably 2.5 hrs at the most if you keep the fuel level down to minimum. Maybe worth getting a galvanised tank cradle for refitting the tank
Post #955554 15th Jun 2022 9:57am
SteveK
Thanks 🙏
Post #955648 15th Jun 2022 10:57pm
SteveK
Well my 110 TD5 went to the garage today and the verdict is that the tank needs replacement. The rear near side is cracked on the top near the sender.
I’m currently looking on eBay for a second hand one because a new one is the best part of £700! Big Cry Big Cry
Post #957941 11th Jul 2022 8:33pm
lightning
Spares parts prices are extortion since LR was bought by Tata.
They obviously think we are all rich Range Rover owners who don't even find out (or care) how much their car repairs cost.
Post #958005 12th Jul 2022 1:01pm
SteveK
Well I found one on eBay at a much more reasonable ÂŁ150!
It’s not just JLR/Tata who have overpriced spares! There was a BMW Mini in the workshop that was having a couple of fuel hoses replaced; the connector on the end of one had failed and had been roughly repaired by a breakdown service. The mechanic asked me to guess what the new pipes cost and I said “About £60”. In fact they cost £300!
Post #958012 12th Jul 2022 1:59pm
Linds Hanson
It makes a bulkhead at ÂŁ5700 or a seat box at ÂŁ2200 seem quite resonable Rolling with laughter
Post #958037 12th Jul 2022 4:49pm
The extortion predates TATA, the prices for parts rocketed when Caterpillar won the distribution contract from Unipart.
I'm not usually slow to criticise JLR but in this instance I'm not sure that it is the villain of the piece, I think a lot is down to the distribution contractor. Mind you, JLR awarded them the contract.
Post #958039 12th Jul 2022 5:32pm
SteveK
An additional rant!
I mentioned earlier that the garage that carried out the service advised that the fuel filter housing was leaking and suggested that it had become porous.
When I investigated I found that the filter was loose and looked old.
I strongly suspect that the fuel filter wasn’t changed. I’ve looked at the invoice and it doesn’t itemise the filters and just says filter kit.
I have emailed the garage for their comments- I wonder if they will reply?
Post #958086 12th Jul 2022 9:41pm
