Home > Maintenance & Modifications > Jobs For A 200tdi Thats Been Sat For A Few Years
Disco-Skipper
Wales 1985 Defender 110 200 Tdi HT Nato Green
Hi Guys,
I've got a got an ex-MOD 200tdi 110 that pretty much hasn't moved for the last 2-3 years, is there anything that usually needs attending to as a result of a lack of use? Its in fair order and runs and drives fine, I'm just conscious that something might rear its head when I'm miles away from home and leave me stranded
Usual fluids and filters have been done
Thanks for any thoughts!
Post #950850 28th Apr 2022 1:51pm
Disco-Skipper
Oh and I should say that its a 200tdi from a disco 1 thats been swapped in after the original 2.5 N/A lunched itself
Post #950851 28th Apr 2022 1:52pm
Probably not. Just carry out the usual fluids and pressures check, probably worth checking the brake lines are not perished, go round the nipples with a grease-gun and then enjoy it. If there is a problem it'll let you know soon enough.
Post #950860 28th Apr 2022 2:39pm
spudfan
Ireland
Change all fluids and filters. Do the belts as well. Drive it and check for leaks in seals and gaskets as sitting around does them no good. Run your fingers along pipe lines for any bad pitted areas or rust.The front swivels can leak from sitting. Nothing major just the basics. Check your shocks for leaks too. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #950927 28th Apr 2022 9:48pm
Disco-Skipper
Perfect, I'll give it a proper checking over for those bits today - thanks for your help
Post #950970 29th Apr 2022 8:30am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Timing belt would definitely be on my list. Not a quick/easy job but needs to be done.
Post #950971 29th Apr 2022 8:37am
Dinnu
Maybe check if brakes are binding. Go for a short spin, use brakes as sparingly as possible, and then check if any one disc or drum brake has become excessively hot.
Careful if using your fingers to check. Do not ask me how I know Embarassed so ideally an Infra red gun. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #950979 29th Apr 2022 10:03am
Disco-Skipper
Have been thinking about giving it a shot, I'm pretty happy on the spanners and looks relatively self explanatory as long as you're careful. Do they tend to die with age or miles? Pretty sure its only done about 10k miles on the belt its got
Dinnu wrote:
Careful if using your fingers to check. Do not ask me how I know so ideally an Infra red gun.
I'm a fellow member of the no finger prints left club Laughing
Post #950990 29th Apr 2022 10:58am
Dinnu
Contamination can also kill timing belts, fuel or oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #950991 29th Apr 2022 11:06am
spudfan
Ireland
Land Rover recommend changing it every 60,000 miles or every five years.
If you want to tackle it I can email you the pages from the work shop manual but my advice is to get an independent who has done it before to do it. 1982 88" 2.25 diesel
Post #950993 29th Apr 2022 11:13am
Disco-Skipper
By the sounds of it, it'd be wise to just play it safe and do it then
I'll shoot you a PM spud, the manual pages would be much appreciated! Once I see a full breakdown of the job it might put me off and I'll take it to my usual guy to do but we'll see
Post #950996 29th Apr 2022 11:37am
spudfan
Ireland
Sent 1982 88" 2.25 diesel
Post #951002 29th Apr 2022 1:05pm
Mo Murphy
The timing belt change is a complex but straightforward job, well within the capabilities of an experienced spanner wielder. It's very important to to use quality parts and not budget parts.
50 Shades of Pennine Grey
Post #951049 29th Apr 2022 7:55pm
Mo Murphy
Double post.
Post #951050 29th Apr 2022 7:55pm
I Like Old Skool
Timing belt is just a bit daunting for most people but in fact is reasonably straightforward apart from the work required to gain access.
Hardest part can often be removing the crank damper pulley bolt (frickin tight) and drawing the pulley off (often glued on with loctite of one sort or another).
If you do go DIY protect the radiator with a piece of hardboard or similar so you don't accidentally shove any tools through it while working in the space between rad and engine Whistle
Post #951084 30th Apr 2022 8:14am
