Home > Technical > Fuel line connectors broken
Page 2 of 2 <12
MalteseRover
Malta
Hello
i was told such pipes do not like to be warmed up because of age. I have sourced a used plastic connector from the discovery but it looks quite shorter when compared to the defender one.
I was about to try heat the pipe and press it (with some of the outer rubber layer removed as it would foul against the green clip.
I am concerned now as it has been sitting for a week Sad
Post #985978 17th Mar 2023 11:17pm
MalteseRover
Malta
hi, I managed to obtain a non defender connector (from a european engine) it is had 3 barbs and as long as the one that i removed. I managed to press it in the pipe but i kinked the pine in one instance Sad will see how it goes. so far it is running fine. It an 8mm OD connector not the 7.89mm. i managed to push it in the pump from the hatch above.
Post #986071 19th Mar 2023 8:38am
Firebird
Finland 2000 Defender 110 Td5 SW Epsom Green
I'm about to replace the fuel hoses WJP107940 on my Defender 110 (yr2000) TD5... as my high pressure hose has a hole in it!
Luckily, I have an inspection hatch in my floor. My questions are... Is it relatively straightforward to physically replace the hoses? Is it just a case of feeding them through and connecting them up?
I know that I have to go through a fuel pump bleeding cycle by pressing the accelerator 5 times etc afterwards... I'm just wondering how hard they are to replace or anything I should know now that'll make it easier to do. I'm very thankful to have the hatch in the floor at least!
Post #1012830 27th Oct 2023 10:25am
jst
mwestcrew wrote:
The tool to fit them is about £80 plus VAT but it does loads of sizes od push in connectors. Very handy to have.
With the tool you can put male and female couplers onto damaged lines as a repair too.
have you a link to this tool please? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1012897 27th Oct 2023 7:18pm
Screbble
Penfold_6290 wrote:
Great to hear you're sorted, I have an inspection plate in my workshop that has been bought specifically for when I have a fuel pump issue. I plan to cut a hole in the floor to access the pump in situ rather than go through the pain of dropping the tank again. The inspection plate will then be fitted over the hole to maintain a watertight seal between chassis and body. This is how you access the fuel pump in a Discovery, I can't understand why they didn't do similar in a Defender.
I do like that inspection hatch, and having had the ‘enjoyment’ of replacing the pump by dropping the tank on my 90 I’d be keen to install one.
Does anyone have the dimensions for its installation or is it a case of trial holes and error…
Post #1012901 27th Oct 2023 7:43pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
Link for tool
https://www.amazon.co.uk/Laser-6933-Pipe-C...amp;nodl=1 2011 130 Utility Body
2005 110 Van
Post #1012942 28th Oct 2023 8:24am
stark
mwestcrew wrote:
...The tool to fit them is about £80 plus VAT but it does loads of sizes od push in connectors. Very handy to have. With the tool you can put male and female couplers onto damaged lines as a repair too.
Do you have a link or a name for this tool please?
Post #1056621 7th Jan 2025 11:49pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Laser 6933 Pipe Connector Insertion Tool
https://www.cromwell.co.uk/shop/automotive...SR5030626C Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1056635 8th Jan 2025 10:01am
stark
Perfect, thanks, apologies I didn't see that mwestcrew had also posted the link!
Post #1056675 8th Jan 2025 3:23pm
Page 2 of 2 <12
