Home > Technical > Fuel line connectors broken |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 |
hi, I managed to obtain a non defender connector (from a european engine) it is had 3 barbs and as long as the one that i removed. I managed to press it in the pipe but i kinked the pine in one instance will see how it goes. so far it is running fine. It an 8mm OD connector not the 7.89mm. i managed to push it in the pump from the hatch above.
19th Mar 2023 7:38am |
Firebird Member Since: 27 Oct 2023 Location: Helsinki Posts: 10 |
I'm about to replace the fuel hoses WJP107940 on my Defender 110 (yr2000) TD5... as my high pressure hose has a hole in it!
Luckily, I have an inspection hatch in my floor. My questions are... Is it relatively straightforward to physically replace the hoses? Is it just a case of feeding them through and connecting them up? I know that I have to go through a fuel pump bleeding cycle by pressing the accelerator 5 times etc afterwards... I'm just wondering how hard they are to replace or anything I should know now that'll make it easier to do. I'm very thankful to have the hatch in the floor at least! |
27th Oct 2023 9:25am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8049 |
have you a link to this tool please? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Oct 2023 6:18pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2103 |
I do like that inspection hatch, and having had the ‘enjoyment’ of replacing the pump by dropping the tank on my 90 I’d be keen to install one. Does anyone have the dimensions for its installation or is it a case of trial holes and error… |
27th Oct 2023 6:43pm |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 262 |
Link for tool
https://www.amazon.co.uk/Laser-6933-Pipe-C...amp;nodl=1 2011 130 Utility Body 2005 110 Van |
28th Oct 2023 7:24am |
