Home > Puma (Tdci) > Intermittent power loss |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20430 |
Plug in and look for DTCโs.
If you donโt have that available to you, lube your turbo actuator pivot points. Try cleaning your MAF and MAP sensors (donโt touch use brake or MAF cleaner only). Check air filter. Consider changing the VCV, look at all the above first before this though. Ideally you want to have it plugged in to find the codes if any are present for faults. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
23rd Apr 2022 6:09pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Could be a delaminating turbo hose? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
23rd Apr 2022 7:32pm |
Jefinabox Member Since: 21 Jul 2021 Location: West Yorkshire Posts: 25 |
Thanks for that, my cheap obdii scanner returned no codes, so I'll clean everything and lube the turbo pivots tomorrow and see what happens.
24th Apr 2022 5:08pm |
One of the few things that doesnโt flag a DTC is the VCV. When that fails or is risking it doesnโt show anything up.
Turbo actuator can get sticky, best to remove the upper linkage carefully and operate wastegate by hand then lube be careful not to lose the circlip. Or if you want to be on the safe side lube the pivot points in situ for now and leave it at that. Worth trying anyway. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช Last edited by custom90 on 29th Apr 2022 7:55pm. Edited 1 time in total |
24th Apr 2022 8:11pm |
Just an update, I followed your advice and cleaned/lubed everything. The problem hasn't been back since and I've got a spare vcv just in case.
Ta |
29th Apr 2022 6:38pm |
Good news. $W33T $0U7H3RN $UG4R
29th Apr 2022 7:55pm |
Ugh, the problem came back so I swapped the vcv for a new one, I didn't do the learning program because I don't have the capability.
Exactly the same thing happens, sometimes it's fine, others I've got no power and loads of smoke. I'll dismantle the actuator tonight and lube properly. |
6th May 2022 9:19am |
