Home > Maintenance & Modifications > CHEQUER PLATE REAR QUARTER PANELS INSTALLATION
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
Hi - attempting to install the Rear Quarter Panel Chequer plate and there is a bolt for a body support that sits on the underneath of the rear body work preventing the Chequer plate from sitting flush.
What did you do to over come this - I have only really noticed whilst going to fix the 2nd one. The fixing hole is obstructed also.
The one I have fitted is now not tight to the underneath as the bolt pushes it out.
Option is to take out the bolt realign chequer plate - drill new hole to where they align to and then refit and then drill a new hole through the Chequer plate and refit the bolt.
Wanted to find out how others may have installed theirs?
Post #949455 15th Apr 2022 4:42pm
Mo Murphy
Take the bolt out, drill through the chequer plate, refit the old bolt (or a new longer one if it's too short)
50 Shades of Pennine Grey
Post #949458 15th Apr 2022 4:58pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
^^^^This. You undoubtedly f'ed up when fitting the first one.....
Post #949509 15th Apr 2022 10:40pm
Trim the CP around the bolt head with a Dremel grind stone or similar tool to finish off.
Measure twice and cut once.
Also unless you already have I’d recommend bonding the CP on and not affixing it with fixings.
I had a bit of impact once on one from a tree branch and it bent the panel a little but the CP came off clean as it was bonded bonded.
I managed to straighten the panel to as new and you’d never know and re-bond the CP and it’s just as it always was 100% damage free now like new.
If those CP pieces would have been bolted on it would have been an awful mess with ripped Alu panel by the bolts and bent up panel and CP piece.
In other words more damage and not so easy to put right. WeWillWin🇬🇧🇺🇸
Post #949510 15th Apr 2022 11:03pm
MattyEssex
Thanks for pointing out the obvious !
It would help if they provided a pre drilled hole for this as well as move the position of the one that interferes with the mud flap bracket.
Post #949513 15th Apr 2022 11:09pm
MattyEssex
Also unless you already have I’d recommend boning the CP on and not affixing it.
I had a bit of impact once on one from a tree branch and it bent the panel a little but the CP came off clean though was bonded.
I managed to straighten the panel to as new and you’d never know and reborn the CP and it’s just as it always was 100% damage free.
If those CP pieces would have been bolted on it would have been an awful mess with ripped panel by the bolts and bent up panel and CP piece.
In other words more damages and not so easy to put right.
Thanks I’ll do this and hope that the new alignment is far enough away from the holes I have already made …..
Post #949514 15th Apr 2022 11:10pm
From memory, the OE ones come with a cut-out in the lip that avoids the bolt.
The problem with providing pre-drilled ones is both cost - it's an extra stage in the manufacturing process - and accuracy, given typical build tolerances. Darren
Post #949560 16th Apr 2022 11:53am
landy andy
The OE ones have a not small cutout around the bolt area, as they know how the tolerance is Whistle
If me I’d fix through the CP as it’s stronger. Although swapping to Gwyn Lewis rear mud flaps is also an idea worth looking at.
Post #949601 16th Apr 2022 9:08pm
