![]() | Home > Maintenance & Modifications > CHEQUER PLATE REAR QUARTER PANELS INSTALLATION |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2324 ![]() ![]() ![]() |
Take the bolt out, drill through the chequer plate, refit the old bolt (or a new longer one if it's too short)
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 842 ![]() ![]() ![]() |
^^^^This. You undoubtedly f'ed up when fitting the first one.....
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
Trim the CP around the bolt head with a Dremel grind stone or similar tool to finish off.
Measure twice and cut once. Also unless you already have I’d recommend bonding the CP on and not affixing it with fixings. I had a bit of impact once on one from a tree branch and it bent the panel a little but the CP came off clean as it was bonded bonded. I managed to straighten the panel to as new and you’d never know and re-bond the CP and it’s just as it always was 100% damage free now like new. If those CP pieces would have been bolted on it would have been an awful mess with ripped Alu panel by the bolts and bent up panel and CP piece. In other words more damage and not so easy to put right. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 Last edited by custom90 on 15th Apr 2022 11:36pm. Edited 1 time in total |
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 ![]() ![]() ![]() |
Thanks for pointing out the obvious ! It would help if they provided a pre drilled hole for this as well as move the position of the one that interferes with the mud flap bracket. |
Thanks I’ll do this and hope that the new alignment is far enough away from the holes I have already made ….. |
From memory, the OE ones come with a cut-out in the lip that avoids the bolt.
The problem with providing pre-drilled ones is both cost - it's an extra stage in the manufacturing process - and accuracy, given typical build tolerances. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5870 ![]() ![]() |
The OE ones have a not small cutout around the bolt area, as they know how the tolerance is
![]() If me I’d fix through the CP as it’s stronger. Although swapping to Gwyn Lewis rear mud flaps is also an idea worth looking at. |
