Home > Technical > what the hell is going on here
Procta
Pulled onto the drive way after my little beer trip from makro, and i bumped into my mam, chatted to her about what had gone on today etc, she happened to notice this
and this
has any one ever saw this happen with their rear lights? one is more distorted than the other. I replaced these a couple of years ago, due to the lens been that badly matted.
bearmach these are. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #949395 14th Apr 2022 7:17pm
gcc130
I’ve had the same in the past on series Landrovers. Obviously got too hot, don’t know why🤷‍♂️
Post #949399 14th Apr 2022 7:26pm
Faulty or incorrect bulb overheating the plastic.
Post #949406 14th Apr 2022 8:08pm
Procta
this is happening on both sides, one side worse than the other, the bulbs came from my local motors factor. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949408 14th Apr 2022 8:19pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
You are obviously a modern style driver using the brakes far too often this melting the plastic lens Rolling with laughter
Try the old school method of anticipation and gears to slow, brakes to stop. Whistle
Or change to LEDs Thumbs Up Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #949409 14th Apr 2022 8:28pm
Procta
not me cuz Laughing
My dad is thinking the bulbs maybe faulty, as i did change these when i swopped the lenses over. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #949411 14th Apr 2022 8:34pm
Dinnu
Those bulbs are 5W for side lights and 21W for brake light. So you can have total of 26W going through. Can generate quite some heat. But ensure that they have been mounted the right way (the bayonet pins are not symmetrial), as if they are incorrectly fitted (trust me can be done), you have 21W side lights and 5W brake light.
Side lights are on for a longer period of time than brake lights. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #949417 14th Apr 2022 9:16pm
Procta
i had a look at the rear lights, to double check the lights bulbs as mentioned, and they are in the correct way. I am suspecting that the plastic lens are poor quality, these were bearmach i have swopped these to wipac or what ever these are called. They seem a better quality. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #951128 30th Apr 2022 6:05pm
Solihull Boy
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
OEM parts always, if possible - also do you sit for long periods with the footbrake applied rather than using the handbrake, say in traffic. There is obviously a heat build up, and no cooling from any airflow Retired from the day job and now self employed - what a life!!
Post #952809 17th May 2022 9:37pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
If you done that the stop start wouldn’t cut in 😁
Post #952813 17th May 2022 10:12pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Something that has been niggling away at the back of my mind since this thread was first posted is that there are differences in the lamp housings from 300tdi onwards and either the lens body or lamp holder that clips into it are different depths depending on if it is designed for a 5W marker light or a 21W stop/indicator light. It's been a while since I have touched my lamps so can't quite remember exact details, but is it possible that the lamp fittings have been mixed up so that the stop lamp is now sitting too close to the lens?
Post #952819 17th May 2022 11:13pm
Dinnu
Aren’t the bayonet pins on the stop/indicator lamp a bit offset? There are also 2 positive connections on that while the side light only has one positive connection. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #952828 18th May 2022 5:49am
