Home > Maintenance & Modifications > Best aerosol for rear cross member
Trendkill110
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Barolo Black
Hello folks.
My 2008 110 DC has some slight surface rust on the face of the crossmember so wanting to tidy it up.
Thinking of a light sand back and spraying the whole thing with a rattle tin.
What do you guys recommend?
Cheers 👍🏻
Post #948886 10th Apr 2022 2:23pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Did mine with Buzzweld CIO about 4 years ago. Still looks good.
Post #948889 10th Apr 2022 3:20pm
Ianh
Corroless S Rust Treatment Killing Inhibiting Primer Followed by Corroless RF16 Glass Leaf Impregnated Gloss Top Coat .
https://www.arc-rite.co.uk/paints
Used on oil rigs so it will last. Both available in spay cans as well as tins for roller, brush or spraying equipment.
Post #948890 10th Apr 2022 3:47pm
kenzle8a
Pretty certain arc rite supply buzzweld with the cio.
Post #948911 10th Apr 2022 6:20pm
Ianh
I think the base for buzzweld cio is corroless, but with a couple of additives. However I expect buzzweld get the corroless base direct or via another supplier.
Post #948918 10th Apr 2022 7:34pm
If you prep it properly then just ordinary satin black. I did mine in this way a year ago and it still looks like new.
https://www.defender2.net/forum/post829009.html#829009 Darren
Post #948934 10th Apr 2022 9:23pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
If you want cheap, Lidl are currently selling black at £4 for 400ml - I think this is meant to be zinc based but do check.
They are also selling off (if they still have it) matte black car paint at £3 per tin or £5 for 2 (these are not zinc). I managed to pick 6 tins up for £15 which I am using for colouring rather than protecting (its going over Bonda Rust Primer). Currently just applied to a rear axle case. I would describe it as more satin than matt. This will have an anti corrosion over it after fitting (one of the clear ones) so I wasn't too worried about protection qualities - though I am not saying it won't provide any protection!
Post #948967 11th Apr 2022 8:55am
MartinK
I used a POR-15 rattle can. Still looking great. Light rub down, then a good scrub with Fertan, then POR-15. Less than an hour's work last summer and still looking good after winter Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #949091 12th Apr 2022 7:07am
Mossberg
This shows great prep work by Darren. I believe painting is all about preparation, especially when trying to cover rust.
I have tried Aquarust and have been very disappointed. You need rust for it to work, but too much rust and it doesn't. I have tried cleaning off the rust to use it, but then you can end up with patches with all the rust removed!! In most cases rust comes back through - or it has for me anyway.
Good luck with the crossmember, I hope you can get it as good as Darren's!
Post #949101 12th Apr 2022 8:45am
