Home > Maintenance & Modifications > Best aerosol for rear cross member |
Trendkill110 Member Since: 04 Sep 2021 Location: Yorkshire Posts: 73 |
Hello folks.
My 2008 110 DC has some slight surface rust on the face of the crossmember so wanting to tidy it up. Thinking of a light sand back and spraying the whole thing with a rattle tin. What do you guys recommend? Cheers 👍🏻 |
10th Apr 2022 2:23pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 353 |
Did mine with Buzzweld CIO about 4 years ago. Still looks good.
10th Apr 2022 3:20pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1952 |
Corroless S Rust Treatment Killing Inhibiting Primer Followed by Corroless RF16 Glass Leaf Impregnated Gloss Top Coat .
https://www.arc-rite.co.uk/paints Used on oil rigs so it will last. Both available in spay cans as well as tins for roller, brush or spraying equipment. |
10th Apr 2022 3:47pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Pretty certain arc rite supply buzzweld with the cio.
10th Apr 2022 6:20pm |
If you prep it properly then just ordinary satin black. I did mine in this way a year ago and it still looks like new.
https://www.defender2.net/forum/post829009.html#829009 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Apr 2022 9:23pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
If you want cheap, Lidl are currently selling black at £4 for 400ml - I think this is meant to be zinc based but do check.
They are also selling off (if they still have it) matte black car paint at £3 per tin or £5 for 2 (these are not zinc). I managed to pick 6 tins up for £15 which I am using for colouring rather than protecting (its going over Bonda Rust Primer). Currently just applied to a rear axle case. I would describe it as more satin than matt. This will have an anti corrosion over it after fitting (one of the clear ones) so I wasn't too worried about protection qualities - though I am not saying it won't provide any protection! Click image to enlarge Click image to enlarge |
11th Apr 2022 8:55am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I used a POR-15 rattle can. Still looking great. Light rub down, then a good scrub with Fertan, then POR-15. Less than an hour's work last summer and still looking good after winter Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
12th Apr 2022 7:07am |
This shows great prep work by Darren. I believe painting is all about preparation, especially when trying to cover rust. I have tried Aquarust and have been very disappointed. You need rust for it to work, but too much rust and it doesn't. I have tried cleaning off the rust to use it, but then you can end up with patches with all the rust removed!! In most cases rust comes back through - or it has for me anyway. Good luck with the crossmember, I hope you can get it as good as Darren's! |
12th Apr 2022 8:45am |
