Home > In Car Electronics > What’s that for? An where can I get one of these..? |
MikeSel Member Since: 21 Mar 2022 Location: UK Posts: 10 |
Seemingly can’t work computers either…..
So - don’t know what this is for… Click image to enlarge As above… Click image to enlarge Rear door switch cable/plug Click image to enlarge Click image to enlarge |
23rd Mar 2022 5:47pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 318 |
The ‘T’ shape is highly lightly to be for a 12v socket - cigarette lighter style.
23rd Mar 2022 7:08pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 319 |
Hi! The white plug with the purple and black wires is the accessory socket which in theory does nothing until you connect something to it. It should provide a permanent 12v supply so if you decide to attached something to it make sure it is switched independently.
For the rear door switch you'll need a PRC8548 'Defender Rear Door Switch' Welcome to Land Rover ownership - you will need a good electrical multimeter! The first job on the interior light is to ascertain if you've got 12 volts at the light itself. The light output is determined by the unit being provided with an earth - either by moving the switch to 'on' or by the central locking ECU where one is fitted. There should be 12 volts at the unit permanently from fuse 30. In my 110 the contacts in the interior light are finicky little so-and-sos and despite there being 12 volts the lamp won't light, so a multimeter will show you if you need to simply shine up the contacts or look further. |
23rd Mar 2022 7:13pm |
Great, thank you both for your replies. Handy having the wiring for the 12v socket ready to go
I’ll dig out my multimeter and give that a go. Thank you for your advice |
23rd Mar 2022 7:59pm |
