Home > In Car Electronics (L663) > VHS/UHF Radio installation
Page 2 of 2 <12
Nice job! The big button on the mic is far too bright. I coloured mine in with a marker pen!
Cool
If you worked HF i’d sched a contact on 10m, but West coast might be a stretch, I worked AZ the other day, that’s as far West as I’ve got so far… but I do have a 3 element quad on the way
Post #979068 21st Jan 2023 8:43am
BobbyR
Australia 2016 Defender 110 2.5 TD SW Pennine Grey
I am very curious to know, can the bonnet still open with the antenna mounted there, or does it hit stuff? I have been considering doing the same mount for an antenna, but I want to make sure I'm not going to have to remove the antenna to open the bonnet. I have an air compressor mounted in the engine bay, and it will be a PITA to have to remove the antenna every time I want to use the thing.
Cheers!!
zilch wrote:
Eventually I got the UHF installed this week, the antenna mount was from Tuff Ant
who’s kit literally is bolted to the passenger side bonnet hinge, zero drilling, just remove one
bolt, loosen the other, slide it in and then retighten the bolts that hold the hinge brackets.
The coax is run under plastic and then pushed/punched through the large steering wheel
grommet into the cabin and ran under the dash, under the diver side footwell panel and into
the centre console.
The UHF unit takes its power from fuse 2 (USB/AUX) in the passenger compartment fuse box
behind the glove box, just used a piggy back fuse and the cable ran behind the dash
and under the footwell side panel and into the centre console space..
The mic is attached to its standard magnetic holder which is double side taped to
a holdmyphone dash clamp
Apart from pushing through the steering column area, zero drilling on any of the install..
Pretty happy with the finished result
Post #1022112 22nd Jan 2024 6:22am
G4R1
I have installed a VHF/UHF radio (strictly programmed to PMR446) a few days ago it only took 2 hours. The mic part comes with a screen and all the controls so main body can be tucked away in the footwell behind the trim. The antenna and 12v feed comes through the gasket in the firewall.
 3.0L MHVE D200 S Pangea Green+Black Pack
Adv. + Off-Road and Family Packs
Post #1036886 9th Jun 2024 8:39am
zilch
Australia
Cheers!!
Apologies for the extraordinary delay in answering Bobby, yes the bonnet opens normally even with a
longer antenna fitted, it is angled to sit above the screen.. no doubt you have already sorted .. oops yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #1037040 10th Jun 2024 5:49pm
Page 2 of 2 <12
