Home > Puma (Tdci) > 2015 110 differentials
Page 2 of 3 <123>
LR90XS2011
I had an ATB in the front only on a 90 for a while I have posted my experience, no weird handling but it would understeer under power in the wet.
I also had the pull to the left it was like the road was on a camber, checked everything and found nothing wrong, it started immediately after install (at Ashcroft approved fitters) and I wished I had gone for the cross pin, however after probably 10k miles it runs perfectly straight.
On hard surfaces with good traction the front ATB also gives better pull to centre under power and better braking.
Now it has settled down I am super happy I have it. I did the back diff as well after the front, and have run a back only.
It was the long thread on here that Blackwolf contributed to that led me to do mine and now I am glad I did.
https://www.defender2.net/forum/topic13545...hcroft+atb DEFENDER 90 TDCI XS,
Post #945492 12th Mar 2022 8:11am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Page 223 of the manual:
"Press the roll pin fully into the planetary gear housing (approximately 8-10mm will protrude from the housing when correctly installed)." Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #945496 12th Mar 2022 9:20am
Now that's interesting! The diff in my photo is a Disco2 rear diff, overhauled and converted to a four-bolt flange. When doing this I didn't disturb the side gears nor differential gears as there was no need. The roll-pin in my photo was fitted by the factory.
This begs the question have the roll-pins got longer? It also now gives you a quandary since there's no way to tell if your diff is perfect with a sticky-out pin, or halfway to a catastrophic failure with a non-sticky-out pin. Oh dear!
I've built or rebuilt about 8 Puma or Td5 diffs in the last 20 years and I've not seen one with a sticky-out roll-pin (although the pin, along with most other parts, was unrecognisable when I took the original front diff out of my Puma after it locked up and shattered). I therefore can't really advise you on this, I'm afraid.
Post #945807 14th Mar 2022 10:41pm
Angus_Beef
it is a bit interesting, and seems par for the course with landrover :lol
the manual I have (from which the above screenshot was nicked) is for 2012 on.
LR workshop shows two part numbers for the roll pin on the diagram for 2007-2016:
PN FTC5402 which was used 1987-2006 and 2007 up to chassis BA
and
PN LR027944 which was used from chassis BA (which should be from 2010)
So now I am speculating that rather than do something logical to counter the diff problem in the Pumas (like put 4 pin fronts), they just put a stronger roll pin in the casing, updated the manual to show that it's longer and sticks out a bit, and went to the pub.
EDIT: New part numbers on casing, cross pin, gears.... did they do a 2-pin update? Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #945830 15th Mar 2022 9:38am
Angus_Beef
blackwolf wrote:
It also now gives you a quandary ...
Yes, but it's the same quandary that the output shaft presents, although there is no real opportunity to check it "while im in there." Until I take it apart and look I wont be 100% sure, but for now at least I'm fairly certain that the visual inspection revealed nothing bad. Based on the info Ive found, the pin should be sticking out a bit on my Jan 2015 and the hole in the casing for the cross pin is not wallowed out.
Now I have an ATB that I can replace when Im ready (sooner rather than later) and am on the way to replacing all three which is something thats been on my wish list.
And hats off to Ashcroft and team - my new ATB and associated parts and supplies arrived Yesterday morning! Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #945831 15th Mar 2022 9:50am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Angus_Beef wrote:
I guess the question now is to go for the ashcroft 4 pin or ATB.
Most here would probably say ATB, but I have some concerns:
- ATB only in front makes weird handling?
- Have read the ATB makes the truck pull to the left at first?
4-pin front makes the front and rear approximately the same.
- marginally cheaper. no worries?
I think I'll order one of the two in the coming days as that roll-pin being already half way out is at best making for an even weaker diff, and at worst is a harbinger of doom. I need to drive back to Norway in May and I can't have this thing break on the highway with a full load, wife, dogs, etc.
Fun.
EDIT: Would you guys replace the crown wheel bolts?
I have an ATB and Ashcroft shafts and drive members in both ends of my 300Tdi 110 and will do the same again in the Puma when I get around to it. Slightly odd/stiff feel to the steering for the first couple of minutes driving until the oil warms up a bit, and now there are a few miles on it I literally don't notice it at all after that but it's spectacular off-road. A 4 pin centre is nearly the same cost and exactly the same amount of work to fit. ---
2006 Defender 110 SW 300Tdi β€’ 2011 Ford Ranger XLT crewcab β€’ 2015 Defender 110 Station Wagon Utility TDCi
Post #947501 30th Mar 2022 10:06am
Angus_Beef
I wonder where all my pictures went? Anyway, I'm finally getting around to fitting the front ATB diff center.
The plan is to remove the 14mm (9/16?) bolts that hold on the swivel balls and move them out just enough to get the diff carrier out.
Question about the seal between the swivelball housing and axle tube. I assume there is a gasket in there and I was not planning to replace it. should I seal it back with black rtv or hylosil?
I guess I'll just have to tighten swivelball housing the bolts up "pretty good" since there is not really a way to measure torque on them?
Nige has a great video on replacing the diff center and that's the method I will take. Seems pretty straight forward. I'll allow a day to get it all done because I am slow doing things the first time Laughing Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #955994 20th Jun 2022 9:42am
Dinnu
Indeed, there is a gasket between the swivel ball and the axle tube. If it was mine, I would want the gasket, and add sealant on either side of the gasket for double measure.
Yeah, normal torque wrenches will not fit, but there are a few tricks to measure torque:
1. Use a spring balance at the end of your spanner. Multiple the Newtons required on the spring balance by the calculation of 100/distance spring balance to bolt in centimeters. Always pull the spring balance perpendicular to the spanner.
2. You can use the torque wrench on a spanner. Most common open ended spanners have 12 point ring for the bolts, and the open end. Size is 9/16” or 14mm. Problem is that a 1/2” drive torque wrench will fit a bit loose in the 9/16” or 14mm open end, but still doable. If you set the torque wrench perfectly perpendicular with the spanner, then the torque setting on the torque wrench is exactly transmitted to the bolt. If not exactly perpendicular, you will increase the torque on the bolt by the ratio of torque wrench to spanner length and the angle between them.
Edit: if going for spring balance method, and spring balance is in Kg, then divide the specified torque required by 9.81 to convert from N to Kg. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #955996 20th Jun 2022 10:11am
This is the normal way to do the job if you don't want to strip the whole axle. A few thoughts based on my experiences swapping out my front diff (which I have had to do more than once now):
  • I left the front wheels and tyres on then jacked the front axle up and put it on stands so that the front wheels were just resting on a pair of machinery skates. The front hub assembly, with or without wheels is extremely heavy and doing this allowed the skates to take the weight. The first time I did the job I didn't use skates and had the wheels resting on the blade of a spade, so that pulling the spade handle pulled the wheel. The skate method is easier! It doesn't have to be a machinery skate, of course, a sturdy board with castors would do just as well.
  • You will of course need to disconnect the drag link and the tie rod. After you have done this, and you then detach the swivel hub from the axle tube, unless you take steps to prevent it the weight of the steering arm on the rear of the swivel hub will cause the rear end to drop, rotating on the wheel bearings, and the weight will be taken by the brake hose. This is not a good idea, so you will need to make sure that there is protection in place before it happens. I cut two length of 3"x3" fence post of the correct length to support the steering arms.
  • You really don't need a torque wrench for the axle tube to swivel hub bolts. I don't understand why there is such an obsession with torque wrenches nowadays, I can only assume that it is a substitute for confidence, experience, or common sense. If you do them up "fairly tight" (note, not "absurdly tight") with a long ring spanner you will have no problems. Torque wrenches are really only important in situations such as cylinder heads where there is a number of bolts which need to be the same tightness, or when bolting through an aluminium alloy part which might get crushed, or when the thread is formed in a soft metal, or you are using a unconventional fastener material, or working on aircraft. For steel through/to steel fasteners in a fairly non-critical application common sense combined with experience is a more useful tool!
  • I also always give the warning to beware the weight of the diff assembly if you haven't done the job before. It is possible for one person to lift the diff assembly down and up from under the vehicle, but it is sufficiently heavy to give you a life-changing injury if you drop it on a squishy part of your anatomy or on your rib cage. The current pinion housing will be stuck in place with Hylosil and may require a certain amount of violence to separate it from the axle tube, so when administering said violence leave two or three nuts loose but on their threads so that it can't unexpectedly fall right out.
  • Hylosil or Hylomar will be entirely satisfactory for the swivel hub to axle joint. You won't be able to fit a new gasket unless you remove the swivel hub assemblies completely from the vehicle, and to do that you either need to disconnect the brake lines or remove the calipers from the hubs and hang them up, neither of which is strictly necessary, and either of which will make the job take longer.
It is not clear (at least not to me) from your post if you are replacing the pinion housing assembly complete with the diff, or if you are fitting a new diff into your old pinion housing. The latter is not particularly difficult but does require a certain amount of care to set the bearing preload and backlash correctly, although you should not have to worry about the pinion height. If you are fitting the new diff into the existing pinion housing, you will need a DTI to set the backlash and a peg spanner (which is easy enough to make if need be) to adjust the carrier side bearings.
Finally doing this job also gives you a good opportunity to check you front axle welds for tell-tale cracks and, if you are so inclined, to fit a pair of the reinforcing brackets that Landrover thinks is a substitute for proper welding on the ends of the axle tube. I think a 2015 MY vehicle is considered safe from this particular "feature", but personally I consider the brackets well worth fitting for peace of mind. (See this thread if you are unsure about the feature I mean).
Good luck!
Post #956014 20th Jun 2022 2:54pm
Angus_Beef
Well into it this afternoon but I seem to have hit an obstacle- the diff carrier is glued on incredibly! I have not been able to budge it. I’ll try again tomorrow with a bigger chisel and a bigger hammer to get it started so I can hopefully get a pry bar under it. But man it’s stuck like crazy! Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #956146 21st Jun 2022 9:17pm
htb2
Wales
Be careful you don't damage the mating faces with a chisel.
Try a jack under the prop flange to lift it up and break the seal.
Post #956148 21st Jun 2022 9:24pm
Angus_Beef
That worked πŸ‘πŸΌ Thumbs Up Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #956173 22nd Jun 2022 6:46am
Angus_Beef
Post #956181 22nd Jun 2022 9:11am
blackwolf wrote:
... The current pinion housing will be stuck in place with Hylosil and may require a certain amount of violence to separate it from the axle tube, so when administering said violence leave two or three nuts loose but on their threads so that it can't unexpectedly fall right out. ...
Told you! Rolling with laughter
The jack under the flange method usually works. It is when that just lifts the vehicle that you know you really have a problem!
Post #956182 22nd Jun 2022 9:18am
Your diff looks a lot healthier than my original diff when I removed it!
I was at least lucky that the damage was all confined to and contained within the diff carrier, so the pinion housing, pinion, and crownwheel were undamaged. The diff itself was properly mullered with the differential gears, side gears, and the remains of the pin all fused into a mass of fragments.
Still at least I had Landrover's assurance that the diff was entirely adequate for the job and there was no fundamental strength issue! Rolling with laughter
Post #956184 22nd Jun 2022 9:30am
Page 2 of 3 <123>
