![]() | Home > Puma (Tdci) > 2015 110 differentials |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
I had an ATB in the front only on a 90 for a while I have posted my experience, no weird handling but it would understeer under power in the wet.
I also had the pull to the left it was like the road was on a camber, checked everything and found nothing wrong, it started immediately after install (at Ashcroft approved fitters) and I wished I had gone for the cross pin, however after probably 10k miles it runs perfectly straight. On hard surfaces with good traction the front ATB also gives better pull to centre under power and better braking. Now it has settled down I am super happy I have it. I did the back diff as well after the front, and have run a back only. It was the long thread on here that Blackwolf contributed to that led me to do mine and now I am glad I did. https://www.defender2.net/forum/topic13545...hcroft+atb DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
Now that's interesting! The diff in my photo is a Disco2 rear diff, overhauled and converted to a four-bolt flange. When doing this I didn't disturb the side gears nor differential gears as there was no need. The roll-pin in my photo was fitted by the factory.
This begs the question have the roll-pins got longer? It also now gives you a quandary since there's no way to tell if your diff is perfect with a sticky-out pin, or halfway to a catastrophic failure with a non-sticky-out pin. Oh dear! I've built or rebuilt about 8 Puma or Td5 diffs in the last 20 years and I've not seen one with a sticky-out roll-pin (although the pin, along with most other parts, was unrecognisable when I took the original front diff out of my Puma after it locked up and shattered). I therefore can't really advise you on this, I'm afraid. |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
it is a bit interesting, and seems par for the course with landrover :lol
the manual I have (from which the above screenshot was nicked) is for 2012 on. LR workshop shows two part numbers for the roll pin on the diagram for 2007-2016: PN FTC5402 which was used 1987-2006 and 2007 up to chassis BA ![]() Click image to enlarge and PN LR027944 which was used from chassis BA (which should be from 2010) ![]() Click image to enlarge So now I am speculating that rather than do something logical to counter the diff problem in the Pumas (like put 4 pin fronts), they just put a stronger roll pin in the casing, updated the manual to show that it's longer and sticks out a bit, and went to the pub. EDIT: New part numbers on casing, cross pin, gears.... did they do a 2-pin update? Roaming around π³π΄π¨π Last edited by Angus_Beef on 15th Mar 2022 9:53am. Edited 1 time in total |
Yes, but it's the same quandary that the output shaft presents, although there is no real opportunity to check it "while im in there." Until I take it apart and look I wont be 100% sure, but for now at least I'm fairly certain that the visual inspection revealed nothing bad. Based on the info Ive found, the pin should be sticking out a bit on my Jan 2015 and the hole in the casing for the cross pin is not wallowed out. Now I have an ATB that I can replace when Im ready (sooner rather than later) and am on the way to replacing all three which is something thats been on my wish list. And hats off to Ashcroft and team - my new ATB and associated parts and supplies arrived Yesterday morning! Roaming around π³π΄π¨π |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
I have an ATB and Ashcroft shafts and drive members in both ends of my 300Tdi 110 and will do the same again in the Puma when I get around to it. Slightly odd/stiff feel to the steering for the first couple of minutes driving until the oil warms up a bit, and now there are a few miles on it I literally don't notice it at all after that but it's spectacular off-road. A 4 pin centre is nearly the same cost and exactly the same amount of work to fit. --- 2006 Defender 110 SW 300Tdi β’ 2011 Ford Ranger XLT crewcab β’ 2015 Defender 110 Station Wagon Utility TDCi |
I wonder where all my pictures went? Anyway, I'm finally getting around to fitting the front ATB diff center.
The plan is to remove the 14mm (9/16?) bolts that hold on the swivel balls and move them out just enough to get the diff carrier out. Question about the seal between the swivelball housing and axle tube. I assume there is a gasket in there and I was not planning to replace it. should I seal it back with black rtv or hylosil? I guess I'll just have to tighten swivelball housing the bolts up "pretty good" since there is not really a way to measure torque on them? Nige has a great video on replacing the diff center and that's the method I will take. Seems pretty straight forward. I'll allow a day to get it all done because I am slow doing things the first time ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Indeed, there is a gasket between the swivel ball and the axle tube. If it was mine, I would want the gasket, and add sealant on either side of the gasket for double measure.
Yeah, normal torque wrenches will not fit, but there are a few tricks to measure torque: 1. Use a spring balance at the end of your spanner. Multiple the Newtons required on the spring balance by the calculation of 100/distance spring balance to bolt in centimeters. Always pull the spring balance perpendicular to the spanner. 2. You can use the torque wrench on a spanner. Most common open ended spanners have 12 point ring for the bolts, and the open end. Size is 9/16β or 14mm. Problem is that a 1/2β drive torque wrench will fit a bit loose in the 9/16β or 14mm open end, but still doable. If you set the torque wrench perfectly perpendicular with the spanner, then the torque setting on the torque wrench is exactly transmitted to the bolt. If not exactly perpendicular, you will increase the torque on the bolt by the ratio of torque wrench to spanner length and the angle between them. Edit: if going for spring balance method, and spring balance is in Kg, then divide the specified torque required by 9.81 to convert from N to Kg. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
This is the normal way to do the job if you don't want to strip the whole axle. A few thoughts based on my experiences swapping out my front diff (which I have had to do more than once now):
It is not clear (at least not to me) from your post if you are replacing the pinion housing assembly complete with the diff, or if you are fitting a new diff into your old pinion housing. The latter is not particularly difficult but does require a certain amount of care to set the bearing preload and backlash correctly, although you should not have to worry about the pinion height. If you are fitting the new diff into the existing pinion housing, you will need a DTI to set the backlash and a peg spanner (which is easy enough to make if need be) to adjust the carrier side bearings. Finally doing this job also gives you a good opportunity to check you front axle welds for tell-tale cracks and, if you are so inclined, to fit a pair of the reinforcing brackets that Landrover thinks is a substitute for proper welding on the ends of the axle tube. I think a 2015 MY vehicle is considered safe from this particular "feature", but personally I consider the brackets well worth fitting for peace of mind. (See this thread if you are unsure about the feature I mean). Good luck! |
Well into it this afternoon but I seem to have hit an obstacle- the diff carrier is glued on incredibly! I have not been able to budge it. Iβll try again tomorrow with a bigger chisel and a bigger hammer to get it started so I can hopefully get a pry bar under it. But man itβs stuck like crazy! Roaming around π³π΄π¨π
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 546 ![]() ![]() |
Be careful you don't damage the mating faces with a chisel.
Try a jack under the prop flange to lift it up and break the seal. |
That worked ππΌ
![]() Click image to enlarge Roaming around π³π΄π¨π |
Told you! ![]() The jack under the flange method usually works. It is when that just lifts the vehicle that you know you really have a problem! |
Your diff looks a lot healthier than my original diff when I removed it!
![]() Click image to enlarge ![]() Click image to enlarge I was at least lucky that the damage was all confined to and contained within the diff carrier, so the pinion housing, pinion, and crownwheel were undamaged. The diff itself was properly mullered with the differential gears, side gears, and the remains of the pin all fused into a mass of fragments. Still at least I had Landrover's assurance that the diff was entirely adequate for the job and there was no fundamental strength issue! ![]() |
