![]() | Home > Wheels & Tyres > Quick help |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
they will fit on the rims no problem, will be slightly smaller in diameter so will lower the gearing, turning circle should not be affected as small width change coupled with reduced diameter.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2135 ![]() ![]() ![]() |
Can’t speak from personal experience as I’m still using 235/85/16, but there are many on here who have upgraded to a wider tyre and have not experienced any insurmountable issues.
I do know that the 70 is the aspect ratio so you do need to keep an eye on that in terms of wider tyres and overall diameter as it might throw your speedo reading out. Those with real/proper knowledge and experience will be along shortly to provide you with the info you require. Good luck! |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Thank you both, I think my concern is around them looking too low profile and other owners bullying me
I can see what you mean now, but Defender owners don’t bully - only wave!
As you’ve requested, some pics will help you make your mind up ![]() |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3393 ![]() ![]() |
They will look a bit weird on a 110 as the height is 2+ inches less than a normal 235 tyre.
You will also lose over an inch of ground clearance ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
I think you'll still have some margin of 'safety' before any bullying is appropriate... ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
That reminds me of a Hot Wheels toy I once had
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3516 ![]() ![]() ![]() |
You will probably never break a halfshaft, and you can remove 1st gear from the gearbox if it is a tdci.
But it will look weird. Had an acquaintance that had those tyres on a 90 HT. Never looked right. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
