Home > Off Topic > Blue Lithium Grease
discomog
Blue Lithium Grease
I am just about to carry out a service on my wifes' horse drawn carriage. Each axle is located on a pair of tapered roller bearings and due to signs of wear on the rollers and cages I have decided to replace them.
Due to the relative low cost of these bearings I decided to purchase them from the carriage manufacturer along with some other parts rather than a bearing supplier and incur further delivery charges.
The carriage manufacturer said I should replace the original white lithium grease with blue lithium grease. Does anyone know why I should use blue in preference to white? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #944640 4th Mar 2022 8:27pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
A very stable grease in high temperature use Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #944643 4th Mar 2022 8:42pm
Castrol LM (now LMX) for wheel-bearings for me, it's never let me down, and I'm not bothered about the colour. Very Happy
I can't imagine that high temperatures are a particular problem in horse-drawn wheel-bearings.
Post #944651 4th Mar 2022 9:07pm
spudfan
Ireland
...directly from the horse's mouth? Whistle 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #944676 5th Mar 2022 1:25am
Screbble
Rolling with laughter ^^^ come on, rein it in…
I’m with Blackwolf - Castrol LM(X) - although I am, like Gwyn Lewis, partial to a bit of Morris K48.
I prefer my grease to be grease-coloured Thumbs Up
Post #944691 5th Mar 2022 9:20am
lohr500
I would ask the carriage manufacturer. I guess they must have some reason for recommending using blue over white.
Unless they just happen to have a large 25Kg tub of it and can decant a small amount into a tin for you at a premium price !!
Post #944706 5th Mar 2022 11:52am
spudfan
Ireland
Does "Ann Summers" stock lubricant stuff? Whistle 1982 88" 2.25 diesel
Post #944707 5th Mar 2022 12:02pm
Dinnu
Is there a proper seal to prevent water ingress?
I use Silcolene RG2 for such, but it is red if that helps in the confusion. Maybe Ann^^^ is the supplier 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944708 5th Mar 2022 12:06pm
