![]() | Home > Off Topic > Blue Lithium Grease |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
A very stable grease in high temperature use
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
Castrol LM (now LMX) for wheel-bearings for me, it's never let me down, and I'm not bothered about the colour.
![]() I can't imagine that high temperatures are a particular problem in horse-drawn wheel-bearings. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
...directly from the horse's mouth? ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
![]() I’m with Blackwolf - Castrol LM(X) - although I am, like Gwyn Lewis, partial to a bit of Morris K48. I prefer my grease to be grease-coloured ![]() |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1330 ![]() ![]() ![]() |
I would ask the carriage manufacturer. I guess they must have some reason for recommending using blue over white.
Unless they just happen to have a large 25Kg tub of it and can decant a small amount into a tin for you at a premium price !! |
Does "Ann Summers" stock lubricant stuff?
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
Is there a proper seal to prevent water ingress?
I use Silcolene RG2 for such, but it is red if that helps in the confusion. Maybe Ann^^^ is the supplier 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
