![]() | Home > Puma (Tdci) > Stuck in diff lock |
When driving along you can also bounce it off a raised pavement, the idea being the wheel will loose traction for a second to enable windup to be released. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Thanks all of you guys!
As the car was parked on a slope I tried the full lock in reverse first. Out off difflock instantly. Happy man again. ![]() Good to know there are so many ways to try to unlock the difflock. ![]() |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 ![]() ![]() ![]() |
I do not use diff lock much but have had that problem, I did do as Bob Neville suggested and it worked but I seem to remember it took me two or three goes. Lonewolf's technique looks good.
