Home > Puma (Tdci) > What's "normal"?
ZeDefender
What's "normal"?
Please help stop my paranoia! I need an overview. I have a 2011 Defender 110 and would like to know if it's "normal" for...
1) a significant "clank" when changing gear, especially between 1st and 2nd; and
2) 3rd gear to "snatch" when engaging.
The dealer here (Germany) is pretty hopeless - just wants to sell me an Evoque Sad
My Dad had a 200 (?) in the '80s and I remember it was pretty rough but what should I expect now?
Loads of thanks for any input.
Cheers,
Matt
Post #89449 16th Sep 2011 4:46pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Fairly normal I'm afraid
Post #89450 16th Sep 2011 4:48pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi Matt,
Question is what to consider as significant ?
Do you hear this when shifting gears or when engaging the clutch ?
Is the sound coming from right between the front seats or elsewhere (rear) ?
How many kilometers have you done with this Defender ?
Some noise is indeed pretty normal, I tend to use the clutch as gentle as possible Wink. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #89455 16th Sep 2011 5:26pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Insist on a clutch change, it makes a big improvement Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #89457 16th Sep 2011 5:58pm
rossy
try changing gear slowly - not like you would in a normal car. Having read the many posts on this subject throughout the forum I change gear very slowly and deliberately. Best practice appears to be not to apply any throttle whatsoever until you have let your foot off the clutch after changing gear. It takes a bit of getting used to but if I forget and start slapping it about like my little Peugeot you can hear all manner of mechanical clonky noises ! There really ought to be a section on this in the Owners manual
Post #89465 16th Sep 2011 6:14pm
MK
Maybe it is the friction plate on its way to die Puma 110" SW
Post #89469 16th Sep 2011 6:23pm
ZeDefender
Gawd bless you all sirs!
Clank comes when engaging clutch(can feel it through the gearstick) , "snatch" comes when changing into 3rd gear.
It's only done 5000 miles so I was wondering...
My mind is at rest for now and I will clutch/change gear really carefully but I will also bear in mind the advice about knackered clutch plate etc. With a few years guarantee there's still plenty of time for things to go "properly" wrong...
Have a good weekend,
Matt
Post #89478 16th Sep 2011 6:51pm
Caterham
I completely agree with Rossy Thumbs Up
reprogramme the grey matter and don't drive it like another other car (modern) that you may have experienced
Post #89485 16th Sep 2011 7:24pm
LR09WA
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Re: What's "normal"?
Cheers,
Matt
Ask for the the transfer case to be re-shimmed, this seems to be fixing much of the slack in the drive line here in OZ, certainly sorted my drive line clunking...
Post #89534 17th Sep 2011 12:41am
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Best way to drive a defender is keep foot on brake when
Letting clutch out until biting point is reached, then release
Brake to apply acceleration removing clutch foot at same time Have fun be happy
Post #89548 17th Sep 2011 8:17am
ZeDefender
Wow - thanks - I will go and practice Smile
Matt
Post #89593 17th Sep 2011 2:40pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
Matt
not only is this a good way to do a hill start and is taught by land rover experence, it means that even with a full load and a big trailer the anti-stall keeps every thing nice and calm and under control.
Post #89600 17th Sep 2011 3:19pm
Happyoldgit
To put it simply drive it like a truck and not like a sports car, racing changes will make the drive train as slack as my granny's knicker elastic in no time. Steve.
http://forums.lr4x4.com
Post #89606 17th Sep 2011 3:57pm
ZeDefender
Smile I do but it still snatches 3rd Smile
Post #89617 17th Sep 2011 4:19pm
Naks
Mine has been doing that since new, now on 28Kkm. I am now threatening LRSA with legal action if they do not fix it, and suggested replacing the gearbox --
Post #89748 18th Sep 2011 9:34am
