![]() | Home > Tdi > Fuel cap leak |
Hi all.
Any ideas how to solve this? I haven't overfilled it and I'm keen to get it fixed as it's a big risk to other road users and my fuel account. Is it just a case of new cap or does it just need a rebuild kit. ![]() Click image to enlarge Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Mine was not leaking that badly. Replaced cap and it has been fine.
Old cap was disassembled. It has a rubber coated disc spring to provide the sealing. If this has worn coating or spring temper was poor it will leak. I can’t see a meaningful repair. Bending disc spring will work for a while but would make the temper worse. 1995 Defender 110 CSW 1971 SIIA Lightweight |
Humm sounds like a new one is required.
Will update with findings. Many thanks ![]() Self confessed mileage hunter ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10965 ![]() ![]() |
My old fuel caps leaked and i got one from ebay and that did the job, no leaks, then optimall fuel cap came out for the Tdi and i got one, that leaked on the second fill up, so i went back to the one i bought and it has not leaked once in all the time i have had it, i don't fill it up to the brim, i always leave a space
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I would prefer an original one but this cap does the job nicely ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
