Home > My Defender > Julian long tall and blue
west4x4
So just over a year ago I was offered “Julian” from a friend of mine as it was just sat in his workshop doing nothing.
Now it left Landrover as a 2.5td hard top and over the years changed to a 300tdi R380 with an early wagon body with sold rear panels to make a utility wagon.
First job was to clean it dusty as hell inside and out from storage
Post #941259 6th Feb 2022 3:54pm
LR90XS2011
love the doors DEFENDER 90 TDCI XS,
Post #941288 6th Feb 2022 7:04pm
west4x4
Yes they are great I’ve a thing for blue landrovers with spit doors
Post #941299 6th Feb 2022 8:19pm
I LOVE that 110 Cool
Post #941304 6th Feb 2022 8:34pm
west4x4
So the big wash revealed an issue. Over time most of the seals around the doors and between body panels had deteriorated letting in water. You could see daylight sat inside the rear where the sides met the cappings. So out came the silkaflex around the roof alpine lights.
Once it was watertight (well more watertight than it was) work started on the interior previously it was all bare metal inside with only some rubber mats in the front foot wells this made the interior cold damp and loud.
So the inside was covered first with 2mm silent coat sound deadening then the side panels with a 10mm closed cell firm that was an off cut from work before being trimmed in a black “carpet” again from work offcut from a job we did.
https://www.lazylawn.co.uk/product/lazy-foam/
https://www.lazylawn.co.uk/product/meadow-twist/
Then I trimmed the rest in more black with some decking effect stipe for the rear footwell
Then off came the door cards and silent coat and foam was applied to these the top half of the cards are missing so covered the exposed metal with a strip of black
All this has vastly improved the interior whilst it’s not whisper quiet I can now talk to my daughter in the back at reasonable speeds
Post #941335 6th Feb 2022 10:27pm
west4x4
We went camping in the summer so I made a shelf across the wheelboxes to allow a flat floor and storage underneath. Also allowed me to get the fridge and “kitchen” in
Post #941705 8th Feb 2022 8:46pm
west4x4
Camping shelf still leaves space for dogs but it is along way to lift the in and out
I have since this installed a dog/cargo barrier
Post #941723 8th Feb 2022 10:51pm
L110CDL
Welcome and a great 110 you have got there Thumbs Up Clayton.
Keeper.
Post #941863 9th Feb 2022 10:43pm
west4x4
A few changes have been done inside.
A Tmax duel battery system with twin batteries and an auxiliary fuse box. Unfortunately fitting the second battery revealed some rust to the bottom of the battery box I’ve patched the holes for now and will replace in the future. Possibly with a deeper YRM version.
All new bearmach door seals fitted but still have a water ingress issue on drivers front. Suspect it’s something to do with the roof and gutter.
Added a camp cover saddle bag for added storage nice bit of kit well made and replaced the dash binnacle with a raptor metal one as the plastic had all broken on the original. I’m less impressed with this the finish is great but the fit isn’t a lot of time has been spent getting it reasonably well fitting.
Found my series fume curtain and placed it on the cargo barrier. Helps the cab warm up a bit quicker and with a set of eBay heated seat covers I’m ready for the worst of winter
Finally on the outside I fitted a full HD brownchurch roof rack. It came with the extra strengthening legs to the waistline but they don’ t fit with the older screen hinges. I already put it too work for a couple of jobs putting stone down in some pony gateways
Just had to remember not to got through the drive through Laughing
Post #943695 24th Feb 2022 7:20pm
west4x4
Thank you been along long long time lurker joined up when I had my last 110 back in 2008ish
Post #943696 24th Feb 2022 7:21pm
L110CDL
Great you've come back again, i thought i recognised your name / id Thumbs Up Clayton.
Keeper.
Post #943721 24th Feb 2022 9:21pm
west4x4
New tyre day
33 10:50 15 general grabbers. Drives much nicer now the BFGs were knackered
Post #945313 10th Mar 2022 4:55pm
L110CDL
Looking good there with the new tyre's Thumbs Up Clayton.
Keeper.
Post #945465 11th Mar 2022 8:41pm
west4x4
Splashed out and treated myself to a new radio. Gone for a Chinese android unit single din with a 9” touchscreen. I was set on a 7” screen but the 9 was cheaper and hey 2 extra inches isn’t to be turned down.
Went for a unit that had a physical volume knob as thought be easier to use in a Bumpy Landrover.
Bonus of the unit screen is can be used with google play store so can run mapping software for greenlaning.
Also we went camping and it rained. Trusty tarp came to the rescue who needs expensive awnings?
Post #954556 4th Jun 2022 6:22pm
west4x4
So after suffering. Dreaded diesel runaway a new turbo and head gasket have been fitted. Also picked up some new(to me) exmoor trim high back rear seats. They do nothing for the legroom but better for necks and backs than the low originals.
Also a fresh MOT with just headlight aim and a small oil leak being the only issues
Post #962566 22nd Aug 2022 9:25pm
