Home > My Defender > Julian long tall and blue |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
love the doors DEFENDER 90 TDCI XS,
6th Feb 2022 6:04pm |
west4x4 Member Since: 23 Jan 2010 Location: Rutland Posts: 140 |
Yes they are great I’ve a thing for blue landrovers with spit doors
Click image to enlarge |
6th Feb 2022 7:19pm |
I LOVE that 110
6th Feb 2022 7:34pm |
So the big wash revealed an issue. Over time most of the seals around the doors and between body panels had deteriorated letting in water. You could see daylight sat inside the rear where the sides met the cappings. So out came the silkaflex around the roof alpine lights.
Once it was watertight (well more watertight than it was) work started on the interior previously it was all bare metal inside with only some rubber mats in the front foot wells this made the interior cold damp and loud. So the inside was covered first with 2mm silent coat sound deadening then the side panels with a 10mm closed cell firm that was an off cut from work before being trimmed in a black “carpet” again from work offcut from a job we did. https://www.lazylawn.co.uk/product/lazy-foam/ https://www.lazylawn.co.uk/product/meadow-twist/ Click image to enlarge Then I trimmed the rest in more black with some decking effect stipe for the rear footwell Click image to enlarge Click image to enlarge Then off came the door cards and silent coat and foam was applied to these the top half of the cards are missing so covered the exposed metal with a strip of black Click image to enlarge All this has vastly improved the interior whilst it’s not whisper quiet I can now talk to my daughter in the back at reasonable speeds |
6th Feb 2022 9:27pm |
We went camping in the summer so I made a shelf across the wheelboxes to allow a flat floor and storage underneath. Also allowed me to get the fridge and “kitchen” in
8th Feb 2022 7:46pm |
Camping shelf still leaves space for dogs but it is along way to lift the in and out
Click image to enlarge I have since this installed a dog/cargo barrier |
8th Feb 2022 9:51pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10853 |
Welcome and a great 110 you have got there Clayton.
9th Feb 2022 9:43pm |
A few changes have been done inside.
A Tmax duel battery system with twin batteries and an auxiliary fuse box. Unfortunately fitting the second battery revealed some rust to the bottom of the battery box I’ve patched the holes for now and will replace in the future. Possibly with a deeper YRM version. Click image to enlarge All new bearmach door seals fitted but still have a water ingress issue on drivers front. Suspect it’s something to do with the roof and gutter. Click image to enlarge Added a camp cover saddle bag for added storage nice bit of kit well made and replaced the dash binnacle with a raptor metal one as the plastic had all broken on the original. I’m less impressed with this the finish is great but the fit isn’t a lot of time has been spent getting it reasonably well fitting. Click image to enlarge Click image to enlarge Found my series fume curtain and placed it on the cargo barrier. Helps the cab warm up a bit quicker and with a set of eBay heated seat covers I’m ready for the worst of winter Click image to enlarge Click image to enlarge Finally on the outside I fitted a full HD brownchurch roof rack. It came with the extra strengthening legs to the waistline but they don’ t fit with the older screen hinges. I already put it too work for a couple of jobs putting stone down in some pony gateways Click image to enlarge Just had to remember not to got through the drive through |
24th Feb 2022 6:20pm |
Thank you been along long long time lurker joined up when I had my last 110 back in 2008ish |
24th Feb 2022 6:21pm |
Great you've come back again, i thought i recognised your name / id Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
24th Feb 2022 8:21pm |
New tyre day
33 10:50 15 general grabbers. Drives much nicer now the BFGs were knackered Click image to enlarge |
10th Mar 2022 3:55pm |
Looking good there with the new tyre's Clayton.
11th Mar 2022 7:41pm |
Splashed out and treated myself to a new radio. Gone for a Chinese android unit single din with a 9” touchscreen. I was set on a 7” screen but the 9 was cheaper and hey 2 extra inches isn’t to be turned down.
Click image to enlarge Went for a unit that had a physical volume knob as thought be easier to use in a Bumpy Landrover. Bonus of the unit screen is can be used with google play store so can run mapping software for greenlaning. Also we went camping and it rained. Trusty tarp came to the rescue who needs expensive awnings? Click image to enlarge |
4th Jun 2022 5:22pm |
So after suffering. Dreaded diesel runaway a new turbo and head gasket have been fitted. Also picked up some new(to me) exmoor trim high back rear seats. They do nothing for the legroom but better for necks and backs than the low originals.
Also a fresh MOT with just headlight aim and a small oil leak being the only issues Click image to enlarge |
22nd Aug 2022 8:25pm |
