![]() | Home > Puma (Tdci) > Truck cab rear window replacement |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
PocketFred, that is extremely interesting.
![]() I was going on what was posted before (I can't readily find the thread unfortunately) which was that the rear window in a TC/DC was not the same size as the side windows in an SW, but it is of course only hearsay. If the part numbers are the same it would be hard to argue that the windows are different sizes. If they are the same it opens up a range of possibilities since any of the gull-wing windows or doors which fit HT side standard apertures should fit the TC/DC. Since I only have a DC I can't compare the measurements, but if someone was willing to measure their SW windows I would be happy to measure my DC window. Postscript: I see from Googling that part number that you are absolutely right, many suppliers list it as both side window and rear window. You learn something new everyday, I'm very grateful to you! ![]() |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I was always lead to believe that truck cab windows were different sizes 🤔🤔 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
Measured my Puma 90, just shy of 1090x460mm. That is including window frame, not hole opening, which I cannot measure without taking the trim off. I believe the Td5 and earlier ones that are riveted, not bonded, have a slightly narrower frame section, but window opening except radius is the same. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I suspect that Fred is talking about the windows used in the sides of ROW spec hardtops, which don't really register over here. Darren
