Home > Technical > Pre filling oil filter on 200tdi and earlier.
Dinnu
Checking maybe someone has a trick up his sleeve.
Normally, when I do a service, I pre fill all filters.. engine oil filter I fill it up so get quicker the oil pressure.
I am about to start for the 1st time my 19J after a full overhaul. Problem is that on 200tdi and earlier, the oil filter is inclined, so very difficult to pre fill.
So anyone has perhaps has a good trick?
I have assembled everything with assembly lube. So maybe I should not worry? Just crank it with injection pump solenoid off? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940079 29th Jan 2022 8:11pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Normally just a big rag around my wrist to slow the flow to my forearm and jumper.
Zip locks bags when removing the old warm oil filter can help.
Post #940088 29th Jan 2022 8:56pm
Dinnu
Thank you Marks. To be honest, I tried to prefill, but I think most oil came out by the time I managed to get the threads connected and spun in.
i had this idea cross my mind after posting... since I have not installed the oil cooler, I could try to prime through one of the oil cooler connections. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940093 29th Jan 2022 9:19pm
Retroanaconda
I half fill it, that way it doesn’t leak out when you tip it to line it up with the threads.
Post #940183 30th Jan 2022 1:10pm
Dinnu
Ok Retroanaconda. I was hoping I could get it a bit less empty. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940190 30th Jan 2022 2:07pm
Mo Murphy
Half fill it, any more just runs down your arm. 👍
50 Shades of Pennine Grey
Post #940204 30th Jan 2022 3:39pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Try lieing the vehicle on its side as you fit the prefilled filter Laughing
Post #940206 30th Jan 2022 3:45pm
Retroanaconda
It doesn’t do any harm to the engine for it to run at idle for a few seconds while the oil pressure builds up, there is very little load on it in that situation. If you’re really worried you could pull the stop solenoid wire off, crank the engine until the light goes out, and then reconnect it to start. I’m not sure it is worth the bother though.
Post #940207 30th Jan 2022 3:47pm
Dinnu
Like that idea Old Skool. Did not cross my mind. Although the way the filter mounts, need to lift the front end by quite a bit Rolling with laughter
Retroanaconda.. I never used to worry between oil changes. But since this is a full rebuild, I may be over cautious. I installed new main bearing / connecting rod big end bearings with assembly lube, and that is quite gooey stuff. Same for the camshaft, although that retained the original bearings.
I will crank it a bit before enabling the fuel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940229 30th Jan 2022 5:25pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
This is what we do with TD5 before starting after refilling with oil.
Post #940343 31st Jan 2022 3:31pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Assembly lube will be more than enough to keep it safe until the oil pressure builds up.
Post #940445 31st Jan 2022 9:37pm
Dinnu
Thumbs Up plan to crank without heater plugs, and fuel off to prevent diesel washing off the oil in the bores until oil pressure builds up, and the squirters do their job (sounds dirty) Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940450 31st Jan 2022 10:00pm
