Home > Maintenance & Modifications > Tub cappings replacement
CarMan
I am thinking I should replace them on my 200tdi 90 as they are rusting on the welds and as I can see it inside as well as outside I am assuming it's not superficial. As the truck is well patinated(!) I really didn't want to paint them so thought galv would look 'period'. So YRM have them new but at £420 and with galv imperfections that have been rubbed down and cold sprayed I'm not so sure. I could by new genuine for £235 and maybe pattern parts cheaper but haven't checked yet. I assume they will be primed only and would need spraying, maybe in a galvanized paint to avoid a colour mismatch. Any thoughts/suggestions?
If I am doing that is there anything else that makes sense to do at the same time?
Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #937365 12th Jan 2022 3:06pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
Everything that's galvanised will have imperfections somewhere, usually where the item has been hung when dipping. YRM are being honest and upfront about it, don't let it put you off. Everything I've had from them has been of great quality.
And if you're unsure, give them a ring and ask. Very helpful bunch.
Post #937373 12th Jan 2022 3:30pm
Alternatively you could buy new either genuine or pattern and get them blasted and galvanised yourself, but the overall cost and quality would likely be similar to YRM.
I have bought parts from YRM in the past and have never been disappointed, in my experience their products are excellent.
Post #937379 12th Jan 2022 4:04pm
Dinnu
Depends on how bad yours are, but there are repair sections that you can cut and weld in. Then I would still go the route mentioned by blackwolf as painting them on the underside is very difficult.
But I am inclined to hot dip everything, as I get good prices locally. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #937386 12th Jan 2022 5:01pm
Oldowner
If you purchase new cappings, the rivet holes are different from the 200tdi on the six visible rivets on the side of the tub, so redriling of the capping will be required.
Post #937654 14th Jan 2022 5:53am
CarMan
Thanks guys for the input 👍🏻 Rob
Post #938216 18th Jan 2022 6:38pm
CarMan
I really need to move this on and assume redrilling of the tub rather than cappings is not an option Question
Post #1010740 10th Oct 2023 12:30pm
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
i have fitted the YRM cappings on my 300tdi that i am rebuilding they look good and fit well.
Post #1010817 11th Oct 2023 6:14am
