![]() | Home > Maintenance & Modifications > Tub cappings replacement |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 ![]() ![]() ![]() |
Everything that's galvanised will have imperfections somewhere, usually where the item has been hung when dipping. YRM are being honest and upfront about it, don't let it put you off. Everything I've had from them has been of great quality.
And if you're unsure, give them a ring and ask. Very helpful bunch. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17712 ![]() ![]() ![]() |
Alternatively you could buy new either genuine or pattern and get them blasted and galvanised yourself, but the overall cost and quality would likely be similar to YRM.
I have bought parts from YRM in the past and have never been disappointed, in my experience their products are excellent. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3532 ![]() ![]() ![]() |
Depends on how bad yours are, but there are repair sections that you can cut and weld in. Then I would still go the route mentioned by blackwolf as painting them on the underside is very difficult.
But I am inclined to hot dip everything, as I get good prices locally. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 648 ![]() ![]() ![]() |
If you purchase new cappings, the rivet holes are different from the 200tdi on the six visible rivets on the side of the tub, so redriling of the capping will be required.
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1885 ![]() ![]() |
Thanks guys for the input 👍🏻 Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
I really need to move this on and assume redrilling of the tub rather than cappings is not an option ![]() |
paul 123 Member Since: 10 Jul 2022 Location: norwich Posts: 96 ![]() ![]() ![]() |
i have fitted the YRM cappings on my 300tdi that i am rebuilding they look good and fit well.
