Home > Td5 > question about spring mount and connector
mruniversum
Germany 2000 Defender 130 Td5 HCPU Scotia Grey
Dear all,
I removed the rear tub from my 130 td5 to weld a part from the chassis, I also want to remove rost and give it a new paint (Owatrol / Ovagrundol and a chassis paint with Owatrol).
Two questions, could be easy to answer for most of you:
What is that cable / connector for near the diesel filter? There was nothing connected. And how can I remove the diesel pipes from the filter (without destroying it:-) ?
Should the spring mount look like this? The metal plate with the four squares seems to be uneven mounted.
Post #937261 11th Jan 2022 9:05pm
ibexman
That’s a spring Mount
Post #937268 11th Jan 2022 9:32pm
mruniversum
Yes of course, you're right.
same question: that plate should not look like this...?
Post #937272 11th Jan 2022 9:37pm
dorsetsmith
connector for near the diesel filter?.. is for
filter water sensor
push gray peace in on both sides
and at same time pall pipe off
Laser Tools 4505 Fuel Line Pliers will help
Post #937279 11th Jan 2022 10:12pm
mruniversum
thx @dorsetsmith
So for removing the pipe I just have to press both pins at the same time, dont have that nice tool.
The water sensor is standard or optional on the td5? There is a filter from "Mahle" mounted, are there filters available with and without the sensor?
I found a kind of cap / valve at the bottom on the filter, seems to be its for draining the water...?
btw, if I remove the filter / the pipes , do I have to (how?) release the preassure from the diesel pipes? (could be also done by the cap / valve on the filter)
Post #937311 12th Jan 2022 8:18am
dorsetsmith
water sensor is standard on pre 2002 td5 (but no in put ecu only indicate on dash)
Pressure from the diesel pipes? only 0.5 Bar from pump and fuel retune engine
Post #937315 12th Jan 2022 8:54am
