Home > Td5 > Cleaning out intercooler
alexatnd
Sadly I've just had a catrastrophic turbo failure on our TD5 and am in the process of stripping out everything from turbo round to EGR valve for cleaning prior to fitting new turbo.( hate turbo -> exhaust nuts .... but a dremmel is your friend)
Fair amount of oil in the intercooler so I filled it with Gunk Ultra de-greaser for the night and emptied it the next morning.
Question is , do i need to do any more flushing out of any de-greaser that might be left in there b4 putting it back in, and oif so what with ?
Intercooler is an allisport one and checked with them to see if degreaser would be o.k.
Rgds
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #936318 4th Jan 2022 4:57pm
ibexman
Methylated spirits Wink
Post #936332 4th Jan 2022 6:47pm
Oldyellar
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Petrol works a treat
Post #936335 4th Jan 2022 6:50pm
rallysteve
Petrol or brake cleaner would be my go-to.
Post #936343 4th Jan 2022 7:26pm
landy andy
As above petrol or brake cleaner. You NEED to know what you’ve put in there will disappear. Using petrol or brake cleaner means you know it will evaporate so not be ingested. Although you have to wait for it to evaporate.
Post #936345 4th Jan 2022 7:30pm
alexatnd
Well would certainly go with a bang ! Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #936363 4th Jan 2022 9:02pm
I've done it successfully with parafin in the past. After cleaning though, I did flush it through with water and then used a hairdryer to dry out the inside before refitting. Darren
Post #936371 4th Jan 2022 9:49pm
alexatnd
And as it happens I've just ordered 5 ltres of brake cleaner.
Waiting for it to evaporate not a problem given the fun i'm havimng removing the exhaust down pipe -> turbo nuts.
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #936413 5th Jan 2022 10:24am
lightning
What happened to your turbo? Mines on 135,000 miles, was there any warning of the failure?
Post #936438 5th Jan 2022 1:14pm
ibexman
Brake cleaner is just as flammable Laughing unless you pay £££££ for non
Post #936455 5th Jan 2022 3:45pm
alexatnd
well in this case i wasnt out driving when it hapened, my wife was and she said there was a loud rattling noise from "front left" and complete lack of power.
Gertie the 110 has done 220K miles and we've done 135K of that, suspect it was te original one
She managed to drive back home very slowly with clouds of white / grey smoke and got her onto the drive.
Think was really lucky. Took hoses off from turbo to intercooler and it was full of oil. oil in intercooler and in hose from 'cooler to EGR valve.
turbo side of engine covered in oil
Got a new turbo to replace it. Main clue was when i grabbed hold of the impeller shaft in the old turbo, it really isn't supposed to waggle about that much.
5 ltrs of brake cleaner just arrived, going to clean everything with that and rinse out any remaining degreaser from intercooler .
Also going to remove sump just to see what's in there
Post #936521 5th Jan 2022 8:55pm
izack98
Canada 2001 Defender 110 2.5 TD CSW Chawton White
Edd from Wheeler Dealers suggests Acetone to clean an intercooler. (Make sure you wear good quality rubber gloves)
https://www.instructables.com/How-To-Clean-An-Intercooler
Post #936776 8th Jan 2022 4:11am
LR90XS2011
if intake impeller has been damaged parts from it can migrate through the intercooler and pipework into the intake manifold and ultimately the cylinder head, when cleaning the intercooler see if you get any shrapnel out, that may indicate debris has passed through the system. DEFENDER 90 TDCI XS,
Post #936808 8th Jan 2022 11:11am
geobloke
As above and with some white kitchen role wipe inside the intake manifold and see if any metal particles made it that far. If so then it is a certainty they are in your cylinders. As your TD5 has done 220k miles then it is a good time to pull the head, check it over for cracks and inspect the cylinders for debris and scoring. You may be lucky and all it will need is a hone and rebuild. Mind you, if you're doing a cylinder hone then expect to replace the piston rings and crank bearings as well. Some may say just get a wrecker engine and that is the other option, but you never know what has happened to it. Coin toss decision.
As for the cleaning of an intercooler I flush through with petrol to remove the oil and sludge. Really spend time sloshing it back and forth to clean out all the internal channels. Empty. Leave remnants to evaporate. Don't forget to thoroughly clean the external fins with plenty of hot soapy water. Afterwards I tend to attach an old hair dryer to one of the ports and pass warm air through the intercooler to make sure it is bone dry inside and out. Works well and a simple DIY method.
Good luck with the engine Thumbs Up
Post #936812 8th Jan 2022 11:39am
alexatnd
Intercooler cleaned with combination of gunk ultra and brake cleaner.
Lots of sloshing round and ended up using my hot air gun ( low setting) to dry it out.
All silicone hoses thoroughly cleaned inside and out
yup paper in the imitation EGR valve and couldnt see any lumpybits there.
After lots of battlnig with exhaust down pipe nuts managed to remove the old turbo
Bought a turbo technic VVT to put in its place.
[geobloke] engine was just back from fitting a replacement head from engine I had in the garage
one small problem (if you've seen one of the VVTs is fitting the oil feed hose to the turbo.... on an std one thert is enough room to get a socket/spanner in there to remove the banjo bolt. on this one theres just about enough room to get two finger in there to screw bolt in losely, certainy no room for socket or spanner... and it needs to be a 14mm one!
Just wonfering if i need to invest in a laser toolds super slim spanner to get at it!
if this engine is dead, got another 11 TD5 turbo can go on while this gets refettled
Post #939846 28th Jan 2022 12:13pm
