Home > Puma (Tdci) > Clutch slave cylinder - hose diameter for reverse bleeding
Varal
Switzerland 2012 Defender 110 Puma 2.2 Black LE Java Black
Hi to all Defender fans, and happy new year !
Probably a silly question, but due to the placement of the device and some physical limitations, I'm having some problems to reverse bleed my TD4 110 clutch.
I have tried to measure the required hose diameter to plug in the nipple located near the slave cylinder, and as I have no small hoses available at home, I have to buy some.
My findings for the moment seems to confirm a 4mm diameter, but I'm not 100% sure...
Does anyone have experience with that, and could confirm or correct my assupmtion ?
Thank you in advance and best regards
Alain
Post #936083 3rd Jan 2022 9:36am
