Home > Technical > Limp mode help!
Co1
Limp mode help!
Went into limp mode tonight in the same way as it did when an intercooler hose failed. I could hear a much more audible induction noise in the cab. Have checked the hoses and can’t see anything. I took out the sensor from the passenger side intercooler hose and it looked pretty wet with oil. Is this normal or has the turbo given up?
Post #935556 29th Dec 2021 7:07pm
geobloke
Well oil in the intercooler is a fairly common thing, really depends on how much oil. It is also the reason many people fit a provent 200 in to their vehicles, to prevent oily gasses making it back in to the intake system.
Anyway... Induction noise. Perhaps a blown intercooler?!
Post #935557 29th Dec 2021 7:10pm
Ianh
That’s the “Air Charge Sensor” part number LR032216 on a 2.2 puma.
That’s what LR call it but in reality I think it’s an Air Charge Temperature Sensor.
Whenever I have taken it out to check or give a clean with a maf cleaner spray it’s been dry, no oil.
What DTC’s are showing Co1
Post #935561 29th Dec 2021 7:31pm
Co1
The odd thing it that it is only making the whooshing sound in the cab when driving. If I’m in neutral it revs freely.
Post #935563 29th Dec 2021 7:34pm
Co1
The hose from the turbo to intercooler wasn’t the tightest at the turbo end, got a good couple of turns on it.
Post #935565 29th Dec 2021 7:40pm
Co1
Just twigged. When I changed the intercooler hoses, I didn’t do the short elbow as I just could work out how to do it!! Just felt round the bottom of it there is a bloody hole in it!!
Post #935571 29th Dec 2021 8:16pm
Ianh
Good you managed to find the culprit, someone else’s on here about a week ago had the same hose fail. If they replaced it they may have some tips on how they did it.
Post #935575 29th Dec 2021 8:49pm
Co1
It’s the air inlet manifold hose that has split. Part 7. Looks like a pig to fit
Post #935581 29th Dec 2021 9:01pm
