Home > Technical > Limp mode help! |
Well oil in the intercooler is a fairly common thing, really depends on how much oil. It is also the reason many people fit a provent 200 in to their vehicles, to prevent oily gasses making it back in to the intake system.
Anyway... Induction noise. Perhaps a blown intercooler?! |
29th Dec 2021 6:10pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2100 |
That’s the “Air Charge Sensor” part number LR032216 on a 2.2 puma.
That’s what LR call it but in reality I think it’s an Air Charge Temperature Sensor. Whenever I have taken it out to check or give a clean with a maf cleaner spray it’s been dry, no oil. What DTC’s are showing Co1 Last edited by Ianh on 29th Dec 2021 6:34pm. Edited 1 time in total |
29th Dec 2021 6:31pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 |
The odd thing it that it is only making the whooshing sound in the cab when driving. If I’m in neutral it revs freely.
29th Dec 2021 6:34pm |
The hose from the turbo to intercooler wasn’t the tightest at the turbo end, got a good couple of turns on it.
29th Dec 2021 6:40pm |
Just twigged. When I changed the intercooler hoses, I didn’t do the short elbow as I just could work out how to do it!! Just felt round the bottom of it there is a bloody hole in it!!
29th Dec 2021 7:16pm |
Good you managed to find the culprit, someone else’s on here about a week ago had the same hose fail. If they replaced it they may have some tips on how they did it.
29th Dec 2021 7:49pm |
It’s the air inlet manifold hose that has split. Part 7. Looks like a pig to fit
Click image to enlarge |
29th Dec 2021 8:01pm |
