![]() | Home > General & Technical (L663) > Adaptive Cruise Control |
sabrutanz Member Since: 07 Aug 2023 Location: Cape Town Posts: 1 ![]() ![]() |
@Bruce (OP) wondering if you ever managed to retrofit the ACC to your Defender? I'm also in SA and also looking into it.
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Compared to other cars I've had, the ACC on my Defender is crude, slow to react and gets confused switching lanes with slower vehicles you are overtaking. I use it but don't like it. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 524 ![]() |
I've found that ACC struggles a bit in very heavy rain / snow. I'm not sure if it's the amount of liquid on the sensors or if it's the mass of water between my vehicle and the next causing confusion, but on a couple of occasions it's simply given up and told me to drive the damn thing myself. I do, however, really like it and use it a lot. |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 276 ![]() ![]() |
I believe the ACC uses both the camera and radar, and the few times I've tried it under extreme rain and snow it does cut out.
Having said that I prefer and feel much more in control of the vehicle if I drive it myself under those conditions. ACC has a habit of taking off like a scalded cat when the road clears and is a little slow on the brakes when cars bunch up. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
