- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Co1
Dinnu wrote:Find a garage that have some welding skills, a flexible exhaust joint, and it can be done.
Although not on a Defender, I replaced the one on my Golf... since I have the welding equipment it only cost me €10 for the flexible joint and about 1hr work (need to get the front part of the exhaust out to weld around).
You do not need a flexible joint of the exact same length... just cut the exhaust pipe accordingly. But diameter wise should be exact.
This! Just look for a custom exhaust specialist. They will be able to sort it for not a lot of cash in comparison to a full section.
4th Jan 2022 9:18pm |
