Home > Off Topic > Any experience with Trailer Servicing Servicing (Ifor)
rallysteve
Afternoon all,
Just wondered if anyone had any experience of trailer servicing costs, in particular Ifor Williams?
The other half works for a local Animal Rescue Centre who have an twin-axle Ifor Williams Horsebox. The cost of the service on it last time it turns out was £1000 which seems a little steep to me. Apparently there was nothing they knew of which was wrong with the trailer when it went for the routine service and the invoice is not itemised.
I know Ifor parts are somewhat expensive but even if it had had all four sets of brake shoes replaced I cant see that getting upto £1000. The service was done in South Yorks/North Notts (i.e. not London area).
Cheers,
Post #934404 20th Dec 2021 5:43pm
hank
I did make some enquiries to have mine service a while back but the estimates were eye watering so did it myself in the end.
I have an Ifor Williams GD105... Aka general duty builders trailer and can't see there is much to go wrong with it. Brake system, wheel bearings and structure.
I gave it the once over and ended up putting brake cables and pads on it. Once you work out what brakes you have fitted (see here http://www.uk-trailer-parts.co.uk/identifying-trailer-brakes/ ) it's all simple stuff and parts are generic and reasonable.
Do they need to have it serviced by an authorised service place for insurance/corporate reasons? > 110 XS Double Cab
Post #934409 20th Dec 2021 5:52pm
rallysteve
Yeah sadly so or I would suggest a more sensible solution.
Cheers,
Post #934410 20th Dec 2021 5:57pm
discomog
Hi Steve. I have an Ifor Williams HB511 horse trailer. It was last serviced a couple of years ago at the IW dealer near Leeds. It was just a routine inspection and service and required no parts. Cost was less than £300.
Being an ex pat Yorkie there is no way I would have paid any more. I had a full brake reline on a previous IW HB510 along with a service and that was under £500. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #934414 20th Dec 2021 6:05pm
martinf
I also have an HB511 horse trailer.
It was serviced a couple of years ago and had a full service with the brakes relined and few minor other items. Total cost £435 in Sussex
Post #934416 20th Dec 2021 6:27pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Parts for ifor Williams are pretty reasonable if it’s axles or hitches, it when you get on to body work they can get dear.
I look after a number of ifor Williams trailers and more recently overhauled the brakes on a HB510, which included brake shoes/back plates /cables/hub nuts and caps the parts was around the £350 mark for the parts. They have really over charged you!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #934459 20th Dec 2021 9:48pm
TJ101
Re: Any experience with Trailer Servicing Servicing (Ifor)
Can see how anyone can charge a grand, let alone pay it, without a itemised invoice
I am a Brian James dealer , and even on a tri axle trailer service, you would really struggle to get to a grand, Shocked It must have had shoes, cables, all lights and a rewire for that California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #934465 20th Dec 2021 10:08pm
TJH1985
I paid £230 for my Hb511 to be serviced. I feel robbed when I pay £210 for the approved workshop to service my twin axle caravan which at least includes a electric/gas/water service also never mind the one year old HB511.
Post #934473 20th Dec 2021 10:40pm
recordman
I had my single axle caravan serviced last week. It was found that the brake linings had disintegrated requiring new shoes and because the drums had been scored they were replaced too.
The cost of this work added another £460 to the bill. If it was a twin axle 'van then obviously the cost would have been twice that amount and taken the bill to close on £1k.
Maybe something like this was needed on your Ifor, but obviously an itemised bill/explanation is needed.
Post #934483 20th Dec 2021 11:53pm
rallysteve
Thanks all, after a bit more digging it turns out that the service was done by a local trailer place, not an IW dealer/service centre anyway. Seems that they have just been being ripped off!
On this basis I have suggested that they approach the large caravan sales/service place which is only a couple of hundred yards down the road from them to see if they are willing to at least inspect and adjust brakes annually.
Cheers,
Post #934511 21st Dec 2021 11:39am
RobKeay
Brakes and bearings on our tipper came to about £600 odd and we fitted them ourselves. That’s got two axles. The ram isn’t too expensive but bit of a pig to fit.
Post #934519 21st Dec 2021 12:16pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I have two IWT and never bother with servicing. I do manage to store them inside which helps and then swap them in for new every few years which is probably as economical as paying for service. Used values are really strong.
Post #935114 26th Dec 2021 11:26am
