![]() | Home > In Car Electronics (L663) > 92% is it actually possible to get any higher? |
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 ![]() ![]() |
yep still same here...
if there is a bug fix it would be good to know it - or is it a dealer visit? L663 90ht |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
I'm sure somebody on one of the facebook groups said they had to take theirs in to have a fix applied which cured the problem, but I can't find that post now. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 257 ![]() ![]() ![]() |
It's the same across Pivi Pro. My old JLR company car Discovery Sport did the same from new.
Had to be sorted at the dealer. Thankfully I'm out of my JLR employment, rid of the loathsome thing and back in my 110 utility everyday! |
47643 Member Since: 30 Sep 2021 Location: central Posts: 26 ![]() ![]() |
found the face book post re above.
it says the instrument pack cluster was updated. is this a hardware or software fix? Update. was at the dealers to resolve this issue. could not sort it. raised a case with landrover. I asked the original facebook poster and he said updated instrument pack. not sure if things get communicated within land rover x series 3 88 x 101 101 90 ht |
I asked the original facebook poster and he said updated instrument pack. not sure if things get communicated within land roverĀ x series 3 88 x 101 101 90 ht |
been to dealer, supposed to have been fixed by s/w . still the same max92%.
back to the dealers next month fir a few days to see if LR can get the fix to them x series 3 88 x 101 101 90 ht |
Velar-P250 Member Since: 27 Jun 2022 Location: VLAANDEREN Posts: 1 ![]() ![]() |
I have the same problem. I have the velar MY21 P250 and the best I can get is 92% efficiency in Eco data score 5,1,5. I saw the same issue at discovery sport forum also with no answer. It is the only problem I have and the service interval is 2years or 34000KM so will it be a bad idea to wait another year to go to the dealer? Can it be a sensor fault or only software?
https://www.discosportforums.co.uk/threads...-21.12217/ [/url][/u] |
update from dealer. its back to LR to sort a software bug and a new release of software.
it affects various models. my courtesy car evoque, has the same problem. no timescale yet for new software x series 3 88 x 101 101 90 ht |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 594 ![]() ![]() |
When is works right it is possible to hit 100% I know it was a short journey
![]() Click image to enlarge And my best mpg so far. Car only has 400 miles on it so should get better with time. Most of the journey done using adaptive cruise ![]() Click image to enlarge |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3034 ![]() ![]() |
How do you activate the eco driving score? When l
look at the screen everything is always on zero. Do l have to set "eco" in the driving modes or is there a button to start it?. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3460 ![]() ![]() |
It should automatically record each journey. 24MY 90 D250 HSE, Tasman Blue
The dealer phoned, the s/ware is available on some cloud based database but there seems to be no application to get it on the vehicle. Has anyone had the update done and can they tell me what the dealer did to fix the issue? x series 3 88
x 101 101 90 ht |
Hi, 90 was in for a recall today,N683
and at the same time the mechanic uploaded new software to the instrument pack module the 92% issues appears to have been solved. spoke to the mechanic. it was a software upgrade to the instrument pack module now shows the middle icon moving above 1 and 99/100% on the display. will monitor to see if this is the long term fix. fix done at Pentland Stirling x series 3 88 x 101 101 90 ht |
