Home > P400e Area (L663) > Is it possible to remote start for climate using EV only ?
Harty
When I remote start the climate control on my p400e Defender, it starts the petrol engine rather than using the electric engine to heat the car.
Is there any way to just start the electric engine to heat it up remotely ?
Thanks,
Harty
Post #933644 15th Dec 2021 10:41am
markb110
Wouldn’t that just make the poor range even worse?
Post #933654 15th Dec 2021 11:51am
Tim in Scotland
There’s a thread in the general section about this issue - the pre-conditioning on the EV side will only work when it’s plugged into the main electrical supply - either a home socket/charger or on a public charger.
This was the same on the Mini PHEV I ran for two years and was to save the ev side of things for maximum range from the relatively small battery (7.5kw battery in that case) My new Mini Electric (with a 32.5kw battery) will precondition without being plugged in and has a heat pump to reduce the electrical consumption when pre-conditioning. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #933657 15th Dec 2021 12:28pm
Harty
Thanks Tim, but my remote app doesn't seem to provide any option to use EV even when plugged in. Do you have a link to the thread (no worries if not).
Post #933663 15th Dec 2021 1:32pm
Harty
... found it. Please ignore the above !
Post #933678 15th Dec 2021 3:16pm
Ritson
France
Harty
Can you please enlighten me as im yet to work out how to remote start preconditioning using the battery, rather than the engine
Cheers Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #933681 15th Dec 2021 3:59pm
Harty
On your phone in the app, click Remote at the bottom, then on the Climate option at the top there is a downward arrow next to it - click the arrow and it lets you select between Engine or Battery climate.
You don't need to have your charging cable plugged in - just checked.
Post #933684 15th Dec 2021 4:30pm
Ritson
France
Thanks Harty!!! Simple when you know how Laughing Current: MY22 P400e SE
Post #933705 15th Dec 2021 5:35pm
hezor
Finland
It's not actually necessary to have the Defender plugged in. It just needs to have a sufficient charge on the battery. 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen
Post #933837 16th Dec 2021 1:01pm
