Home > P400e Area (L663) > Is it possible to remote start for climate using EV only ? |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2650 |
Wouldn’t that just make the poor range even worse?
15th Dec 2021 11:51am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
There’s a thread in the general section about this issue - the pre-conditioning on the EV side will only work when it’s plugged into the main electrical supply - either a home socket/charger or on a public charger.
This was the same on the Mini PHEV I ran for two years and was to save the ev side of things for maximum range from the relatively small battery (7.5kw battery in that case) My new Mini Electric (with a 32.5kw battery) will precondition without being plugged in and has a heat pump to reduce the electrical consumption when pre-conditioning. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
15th Dec 2021 12:28pm |
Harty Member Since: 20 Feb 2021 Location: London Posts: 31 |
Thanks Tim, but my remote app doesn't seem to provide any option to use EV even when plugged in. Do you have a link to the thread (no worries if not).
15th Dec 2021 1:32pm |
... found it. Please ignore the above !
15th Dec 2021 3:16pm |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 187 |
Harty
Can you please enlighten me as im yet to work out how to remote start preconditioning using the battery, rather than the engine Cheers Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
15th Dec 2021 3:59pm |
On your phone in the app, click Remote at the bottom, then on the Climate option at the top there is a downward arrow next to it - click the arrow and it lets you select between Engine or Battery climate.
You don't need to have your charging cable plugged in - just checked. |
15th Dec 2021 4:30pm |
Thanks Harty!!! Simple when you know how Current: MY22 P400e SE
15th Dec 2021 5:35pm |
hezor Member Since: 01 Feb 2021 Location: Nurmijärvi Posts: 53 |
It's not actually necessary to have the Defender plugged in. It just needs to have a sufficient charge on the battery. 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen |
16th Dec 2021 1:01pm |
