Home > Maintenance & Modifications > Fitted winch bumper |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
And today fitted the winch BUT need to order some longer battery cables and an isolator switch
Click image to enlarge Click image to enlarge Click image to enlarge 🥟 stew |
12th Dec 2021 4:45pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
looks great. can recommend bluesea isolators. good stuff. dont forget a megafuse too.
12th Dec 2021 7:49pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5699 |
Did you not get their (Winchmax) wire kit for Defender?
13th Dec 2021 8:12am |
No I didn’t think about it at the time but will be ordering this morning
13th Dec 2021 8:23am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17378 |
Or have a read of this thread and decide how to protect your winch. |
13th Dec 2021 8:25am |
Thanks for that blackwolf was interesting and informative and very helpful post
13th Dec 2021 8:41am |
The Winchmax comes with a fuse as standard. You can then choose to use it or not.
13th Dec 2021 11:50am |
Will finally got some time today to finish wiring the winch up
Click image to enlarge |
20th Mar 2022 10:55am |
Love a good winch install Love the bumper too, is that based on the LR/Mantec winch bumper? Just wondering if the soft A-bar wold fit over it.
20th Mar 2022 10:59am |
If is the Winchmax bumper then it is a direct copy of the original LR (Mantec) bumper. That is what they informed me.
20th Mar 2022 12:00pm |
That is good to know. Love the LR/Mantec bumper.
20th Mar 2022 12:05pm |
It does feel a very heavy duty winch bumper , just fitted the new longer live terminal but was a bit of a pain getting it on the solenoid terminal and lining up the grommets again when closing the casing , and I’m glad I’ve got my own ramp
20th Mar 2022 12:15pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2636 |
Bit late now but did you measure the distance between your bump stops and front axle.
if it feels a bit bouncy at the front or crashy over speed humps it will be worth changing the front springs. Otherwise it looks supercool. Don't forget to tension the rope before use. |
20th Mar 2022 5:51pm |
Hasn’t made any noticeable difference, being a utility 110 is very firm over speed bumps .
All wired up now and working fine , and as you say just got to tension up the rope as soon as I get chance Click image to enlarge |
20th Mar 2022 5:59pm |
