![]() | Home > Maintenance & Modifications > Fitted winch bumper |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
And today fitted the winch BUT need to order some longer battery cables and an isolator switch
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 🥟 stew |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
looks great. can recommend bluesea isolators. good stuff. dont forget a megafuse too.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Did you not get their (Winchmax) wire kit for Defender?
No I didn’t think about it at the time
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Or have a read of this thread and decide how to protect your winch. |
Thanks for that blackwolf
The Winchmax comes with a fuse as standard. You can then choose to use it or not.
Will finally got some time today to finish wiring the winch up
![]() ![]() Click image to enlarge |
Love a good winch install
If is the Winchmax bumper then it is a direct copy of the original LR (Mantec) bumper. That is what they informed me.
That is good to know. Love the LR/Mantec bumper.
It does feel a very heavy duty winch bumper , just fitted the new longer live terminal but was a bit of a pain getting it on the solenoid terminal and lining up the grommets again when closing the casing , and I’m glad I’ve got my own ramp
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Bit late now but did you measure the distance between your bump stops and front axle.
if it feels a bit bouncy at the front or crashy over speed humps it will be worth changing the front springs. Otherwise it looks supercool. Don't forget to tension the rope before use. ![]() |
Hasn’t made any noticeable difference, being a utility 110 is very firm over speed bumps .
All wired up now and working fine , and as you say just got to tension up the rope as soon as I get chance ![]() ![]() Click image to enlarge |
