Home > In Car Electronics > (probably daft) question about focal speaker size
nick345345
Scotland 2012 Defender 110 Puma 2.2 USW Baltic Blue
Hi all, I'm looking to upgrade the speakers in my 2012 110 Utility to the focal's recommended by many people on here. However I'm confused as what size speaker to buy. I've measured all 4 speakers (2 in dash, 2 at the rear) and they all seem to be 130mm, so I was thinking the PC130's would be direct replacements. But then reading on here and MUD-UKs website suggests that PC100's are direct replacements. Am I missing something?
Thanks in advance,
Nick
Post #933211 11th Dec 2021 5:14pm
Co1
PC100 are the ones for the front, the 130’s go in the rear. Get the tweeters as well, they are very impressive.
Post #933225 11th Dec 2021 6:26pm
DSC-off
Hi, are you measuring the outside diameter of the speaker grille at 130mm, or the diameter of the speaker cone/diaphragm?
Speaker size is the diaphragm size.
The grille is bigger as it covers the metal mounting plate that surrounds the diaphragm.
All standard fit speakers in the Defender are 100mm.
It's very easy to increase the rear ones to 130mm, but a bit more difficult for the front.
Post #933248 11th Dec 2021 10:15pm
nick345345
Ah, that's probably my mistake - I was just measuring the visible grille which was measuring 130mm, probably the source of my confusion. Thanks for the help!
Post #933251 11th Dec 2021 10:33pm
Onemcs
I’ve just installed the 130AC into the rears.
You’ll need to jigsaw the diameter slightly larger.
Fortunately I took a few photos
Post #933488 13th Dec 2021 9:03pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
Excuse the derailing. I've just installed a subwoofer (Audio System Germany US08 Active in a mud housing - carried it around under the cubby box for approx 2 yrs but had it connected last week since I couldn't figure out how to do it myself and was afraid of the cost...for good reason, I know now...) and am about to upgrade to new speakers. Found the PC100's online but not the tweeters: Can I ask you for a part number? Thanks, Christopher
Post #933518 14th Dec 2021 9:57am
Onemcs
The ES100K focal kit is the one I’m installing at the moment in the fronts.
The tweeter and woofer fit in the existing openings. The cross over can go within the dash.
Post #933522 14th Dec 2021 10:13am
Swerni
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Auto Corris Grey
It’s the PC100 in the rear, they are a straight swop.
Unless you’re an idiot like I am, it’s 10 minute job.
Post #933813 16th Dec 2021 10:46am
chek
What are these good for? I don't get it, I am about to replace the stock speakers with Focal PC100's. Thanks!
Post #934833 23rd Dec 2021 3:34pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Make hole in plastic to screw speaker on push this on first and it means screw sticks and does not pull out Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #934837 23rd Dec 2021 4:06pm
DSC-off
Known in the UK as Spire nuts or U nuts.
Post #934839 23rd Dec 2021 4:08pm
chek
Thank you! 👍🏻
Post #934841 23rd Dec 2021 5:14pm
Swerni
I didn’t bother using them, just put the screws in the original holes.
There was plenty of bite.
Post #935248 27th Dec 2021 9:08am
