Home > Wheels & Tyres > Wheel adaptor
Solis
Cyprus 2013 Defender 90 Puma 2.2 LXV Hard Top Santorini Black
Wheel adaptor
Hello guys how easy is it to fit Wheel Adaptor Kit 5/165 to 5/120 on a td5 defender
Post #932546 5th Dec 2021 7:48pm
They just bolt on. This is on a Sankey trailer rather than a Defender but the principle and the bolts are all the same:
The only thing I'd recommend is to use capless alloy wheel nuts rather than the standard ones. The tolerance of the holes in the adapter are very tight and the caps on the standard nuts have a habit of swelling, making them difficult to fit. Capless nuts were standard on the earlier Discoverys but are also readily available as an aftermarket item.
Oh, and depending on the make of the adapters and what wheels you plan to fit, you may also need a spigot adaptor kit to ensure hub centric fitting of your chosen wheel. Darren
Post #932585 6th Dec 2021 6:47am
