Wheel adaptor
Hello guys how easy is it to fit Wheel Adaptor Kit 5/165 to 5/120 on a td5 defender
5th Dec 2021 8:48pm
They just bolt on. This is on a Sankey trailer rather than a Defender but the principle and the bolts are all the same:
The only thing I'd recommend is to use capless alloy wheel nuts rather than the standard ones. The tolerance of the holes in the adapter are very tight and the caps on the standard nuts have a habit of swelling, making them difficult to fit. Capless nuts were standard on the earlier Discoverys but are also readily available as an aftermarket item.
Oh, and depending on the make of the adapters and what wheels you plan to fit, you may also need a spigot adaptor kit to ensure hub centric fitting of your chosen wheel.Darren
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
